ACI fabric automation
gavin han
can we automate fabric and access policies?
I am going through ACI programmability module labs on devnet and it looks like all of these labs/modules are for tenant. I don't see any scripting for fabric and access policies? do we have to configure fabric and access policies manually?
Nik Noltenius
yes, you can automate everything in ACI. In my opinion it takes a lot of effort to find the right objects, parameters and connections but basically it's all out there, publicly available. You just have to find and make sense of it ;)
E.g. this lets you create a VLAN-Pool via Python:
import cobra.mit.access
import cobra.mit.session
import cobra.mit.request
import cobra.model.fvns
# log into APIC and create a directory object
authentication = cobra.mit.session.LoginSession(URL, USER, PASSWORD)
mySession = cobra.mit.access.MoDirectory(authentication)
mySession.login()
# create VLAN Pool with VLAN 123
fabric = mySession.lookupByDn('uni/infra')
vlanpool = cobra.model.fvns.VlanInstP(parentMoOrDn=fabric, allocMode='static', name='TestPool')
vlans = cobra.model.fvns.EncapBlk(parentMoOrDn=vlanpool, from_='vlan-123', to='vlan-123')
# commit changes to fabric
request = cobra.mit.request.ConfigRequest()
request.addMo(vlanpool)
mySession.commit(request)
I'm not a developer so this might not be the best way to do it, but the message is: It can be done!
The online documentation is helpful (https://solutionpartner.cisco.com/media/apicDcPythonAPI_v0.1/index.html), Visore (the Object Store Browser) gives useful hints and the API Documentation on the APIC can also lead you the way.
Nik
