1000v with vCenter on same ESX host
In my lab I have only one ESX server.  On this server I am running VSM and vCenter (appliance).
I am trying to get 1000v working however everytime I try to migrate my ports I get the following error:
Network configuration change disconnected the host '192.168.0.10' from vCenter server and has been rolled back.
fault.NetworkDisruptedAndConfigRolledBack.summary
It seems that it doesn't like the fact that vCenter lives on the same ESX host as I'm trying to migrate.
Anyone have any ideas how I could get this to work?
I've tried both L2 and L3 mode but have failed with both.  I have tried using techniques from the Cisco Cloud Lab L3 tutorial as well as some videos I found on Youtube:
http://www.youtube.com/user/sysadmintutorials/videos?view=0
... But I keep getting stuck in the same place...
My port profile config:
port-profile type ethernet vmware-uplinks
  vmware port-group
  switchport mode trunk
  mtu 9000
  switchport trunk allowed vlan 1-3967,4048-4093
  no shutdown
  system vlan 62
  state enabled
port-profile type vethernet Management
  vmware port-group
  switchport mode access
  switchport access vlan 62
  no shutdown
  state enabled
port-profile type vethernet VLAN_62
  vmware port-group
  no shutdown
  state enabled
svs-domain
  domain id 1
  control vlan 62
  packet vlan 62
  svs mode L2
Also, I can never get the VEM to show up in my VSM when I do a 'show mod'...
Any ideas?
Phillip Wilson
Ok so before you can migrate anything onto the Nexus 1000v (VSM) you have to make sure it has connectivity to the VEM (Host) with the control vlan.  When you do a "show mod" it will show module 1 and 2 as the primary and secondary (if you have an HA) VSM.  When you add a host to the VSM they will fill in below that as module 3, 4 and so on.  Looks like you have it setup to do L2 in your config.  And you say when you do a show mod it doesn't show the current VEM for the host.  From what I have read and setup in live environments is you want seperate vlans for control, packet, and management. and seperate vlans for vm servers. I would create different port profiles for vmtraffic and one for your system traffic (management, control, packet).  If your VSM cannot talk to the VEM installed on the host across the system uplink they VEM will not be added as a module on your VSM.  I don't know how many nics you have on your ESX host, but make one assigned to vmware-uplinks port profile and then assign a seperate one to system-uplinks.  This should work I believe if i have typed this in correctly.  If you have followed the install sheet for the n1k on cisco's site you might need to confirm that the correct VIB is installed on your ESX host as well that is compatibale with the version of Nexus 1000v you have running.  You can download the VIB from your VSM if it's managment is working correctly (on the standard switch) at http://vsm-management-ip.  I hope this helps you out.
Example below.
vlan 50
     name Servers
vlan 61
     name Management
vlan 62
     name Control
vlan 63
     name Packet
  vmware port-group
  mtu 9000
  switchport trunk allowed vlan 50
  no shutdown
  state enabled
port-profile type ethernet system-uplinks
  vmware port-group
  switchport trunk allowed vlan 61,62,63
  system vlans 61,62,63
  no shutdown
  state enabled
  vmware port-group
  switchport access vlan 61
  no shutdown
  system vlan 61
  state enabled
port-profile type vethernet Control
  vmware port-group
  system vlan 62
  no shutdown
  state enabled
port-profile type vethernet Packet
  vmware port-group
  switchport access vlan 63
  system vlan 63
  no shutdown
  state enabled
port-profile type vethernet Servers
  vmware port-group
  switchport access vlan 50
  no shutdown
  state enabled
svs-domain
  domain id 1
  control vlan 62
  packet vlan 63
  svs mode L2
