3745 and waas problem
Muhammed AKYUZ
We are having problem with cisco waas inline port and 3745 f0/0. When we shut the waas, port goes down and it does not work.. we tried 6509 and 3745 switch module we do not have problem..
Bhavin Yadav
Please make sure to follow these cabling guidelines and use the right cable.
Installation  Scenarios and Cabling Examples for Fast Ethernet Connections
It is possible that it might be the bad inline card or bad f0/0 port on 3745.
Regards.
