about pix failover and css failover
qingfeng-hu
the situation as follow:
two css,each separate connect to one pix inside int;
two pix and css configure to failover, polling time 15 sec
set the css type redundancy-up,when pix outside link down or inside link down,standby pix will become active,then it will cause the backup css switch to master,
does it correct?my question is,how can I adjust it to minimum the switch time.
thanks and regards.
qingfeng-hu
it is pix problem,i used the different pix model to made the failover.
