ACE 30 one-arm mode SNAT to same IP as VIP
David Niemann
Level 3
Level 3
Trying to set up a bidirectional connection that source NATs all rserver initiated connections to the same IP as the inbound VIP.  I think I have the config right, but it doesn't seem to work.  The IP that should be used for all comms is a VIP of 172.31.0.176 which you will see in the NAT pool.  the 172.31.0.178 was created as a VIP for the rservers to send outbound to which will be source NATed to the 172.31.0.176.
rserver host RS_XXX_CORP_SMARTHOST_1
  description XXX CORP SMARTHOST FOR EMAIL
  ip address 5.5.5.5
  inservice
serverfarm host SF_EXC2013_SMTP_OUTBOUND
  description Exchange 2013 SMTP
  predictor leastconns
  rserver RS_XXX_CORP_SMARTHOST_1 25
    inservice
sticky ip-netmask 255.255.255.255 address source Sticky_SrcIP_EXC2013_SMTP_OUTBOUND
  serverfarm SF_EXC2013_SMTP_OUTBOUND
  replicate sticky
class-map match-any VS_EXC2013_SMTP_OUTBOUND
  description Exchange 2013 SMTP Outbound
  2 match virtual-address 172.31.0.178 tcp eq smtp
policy-map type loadbalance first-match EXC2013_SMTP_OUTBOUND
  class class-default
    sticky-serverfarm Sticky_SrcIP_EXC2013_SMTP_OUTBOUND
policy-map multi-match Farm_VIPS
class VS_EXC2013_SMTP_OUTBOUND
    loadbalance vip inservice
    loadbalance policy EXC2013_SMTP_OUTBOUND
    loadbalance vip icmp-reply active
    nat dynamic 6 vlan 511
interface vlan 511
  description ACE-DMZ-front
  bridge-group 1
  mac-sticky enable
  access-group input BPDU
  access-group input ANYONE
  nat-pool 6 172.31.0.176 172.31.0.176 netmask 255.255.255.0 pat
  service-policy input PM_AdminAccess
  service-policy input Farm_VIPS
  no shutdown
This config actually worked for me.  I had an issue with the L2L tunnel the traffic was utilizing causing it to be dropped.  Once the L2L tunnel as up it worked as planned.
Wade Patterson
David,
Since the rservers are on a separate subnet from the VIP, do they have a valid L3 path to the VIP?
Ok.  When I looked through the config it didn't appear as if anything was wrong.  Glad you got it fixed.
