ACE 4700 not load balancing
Bruce Summers
Hi folks,
Some assistance if you have the time please.
I'm running an ACE 4700 appliance, i have a 4 server serverfarm setup, non-ssl, with leastconns predictor...i have tried round robin as well, and nothing...
I've taken each rserver out of service, and placed back in, and still, the traffic is handed off only to 1 server...
I do have sticky persistence (IP subnet)....
I'm not sure what i'm missing...
thanks in advance.
8 Replies 8
pablo.nxh
Level 3
Level 3
Hi Bruce,
From your description seems like the problem might be related to NAT or a Proxy in front of the clients, if that's the case you'll need to consider another sticky methods as the clients will show up with the same IP address all the time to ACE.
__ __
Pablo
Probably.
This is called a "mega proxy" issue. For generic protocols it cannont be solved if persistence is required. For HTTP use cookie based persistence instead.
well,
here is the overall infrastructructure:
internet traffic --->  FW  ---> nat public to private of vip of ACE module  -->  Rservers (Web)  --->  FW  --->  4700 vip ---> to
the Rservers i'm having issues with....
the only NAT is further upstream on the FW.
This is SMTP traffic not HTTP...
bruce
Can you give us your config ?
I'm afraid i cannot...I know, makes it that much harder to assist...
bruce
At least the sticky group part ?
I suspect an issue there.
sticky ip-netmask 255.255.255.255 address source IP_STICKY1
timeout 10
serverfarm SERVERFARM1
now that i'm looking at that, is that right?  a /32 source address statement?
To me it's ok.
You can see the content of the sticky table with a "show sticky database" command
