ACE 4710 configuration advice
julxu
Greeting
I want to use one arm infrastruction of ACE4710. But I remember it was problem for backend server can not get logging for which client/ip address access the web server.
Could anyone advice me how can I solve this problem?
Any comments will be appreciated
Thanks in advance
julxu
2 Accepted Solutions
Surya ARBY
Level 4
Level 4
You can put the source ip address of the incoming request into a field oh the http header.
policy-map type loadbalance http first-match WEB_L7_POLICY
  class class-default
    serverfarm SF-1
    insert-http x-forward header-value "%is"
No it works by default.
Please rate this post if it helps.
Surya ARBY
Level 4
Level 4
  class class-default
    serverfarm SF-1
Surya
Great thanks for you reply.
To use policy-map, do I need upgrade license from basic to optimization?  what commands will involve with optimization license?
Please advice.
Many Regards
julxu
