ACE 4710-K9 _fresh instal
Manjunath G
I need to setup new ACE 4710 device , after referring to "Establishing a Console Connection on the ACE" i had managed to set up initial console connection.   During installtion i had configured vlan (default vlan 1000) , interface ip adess& subnet mask.
Post initial config i understand i should be able to open' Device Manager GUI Login Window' but it is not opening.
I  also need inputs on setting 4710 for the telnet connection
Jorge Bejarano
Level 4
Level 4
Manjunath,
I assume you already configured the management configuration, right?
Can you paste it?
I assume you are getting a "blank page" and that's it correct?
Can you get a #show tech-support and after that try to reboot the box?
Additionally, what version are you running?
Jorge
Cesar Roque
Level 4
Level 4
HI,
This is the basic configuration you need to get telnet, https, http, ssh aceess to the ACE:
access-list Allow_Access line 10 extended permit ip any any
class-map type management match-any NSS-ACCESS
  10 match protocol telnet any
  30 match protocol icmp any
  40 match protocol http any
  50 match protocol https any
  60 match protocol ssh any
policy-map type management first-match NSS_MGMT
  class NSS-ACCESS
    permit
interface vlan XX
  ip address x.x.x.x z.z.z.z
  access-group input Allow_Access
  service-policy input NSS_MGMT
  no shutdown
ip route 0.0.0.0 0.0.0.0 w.w.w.w
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Thank you for the revert..
Cesar ! WIll append yur config & let you know the status
Jorge! Installation is being carried out @ client place , will share the config
Manjunath,
What my colleague Cesar pasted is more or less what we would expect to see in your configuration to have this working.
Jorge
