Load balancing across 4 web servers in same datacentre - advice please
carl_townshend
Hi All
Im looking for some advice please
The apps team have asked me about load balancing across some servers but im not that well up on it for applications
Basically we have 4 apache web servers with about 2000 clients connecting to them, they would like to load balance connections to all these servers, they all need the same DNS name etc.
what load balancing methods would I need for this, I believe they run on Linux
Would I need some sort of device, or can the servers run some software that can do this, how would it work? and how would load balancing be achieved here?
cheers
5 Replies 5
sivaksiv
If there is no specific requirement you could just leave it to default LB method round robin.
You could also loadbalance based on stickyness - src ip, cookie, url ..
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/sticky.html
Siva
what do you mean default LB method of Round robin ? what would that be and how would it work ?
Carl,
What you have mentioned sounds very straightforward then everything should go well.
The ACE is a load balancer which takes a load balancing decisions based on different matching methods like matching virtual address, url, source address, etc then once the load balance decision has been taken then the ACE will load balance the traffic based on the load balance method which you have configured (if you do not configure anything then it will use the default which is "round robin"), then it will send the traffic to the servers which it has available and finally the client should get the content.
If you want to get some details about the load balancing methods here you have them:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/overview.html#wp1000976
For ACE deployments the most common designs are the following.
Bridge Mode
One Arm Mode
Routed Mode
Here you have a link for Bridge Mode and a sample for that:
http://docwiki.cisco.com/wiki/Basic_Load_Balancing_Using_Bridged_Mode_on_the_Cisco_Application_Control_Engine_Configuration_Example
Here you have a link for One Arm Mode and a sample for that:
http://docwiki.cisco.com/wiki/Basic_Load_Balancing_Using_One_Arm_Mode_with_Source_NAT_on_the_Cisco_Application_Control_Engine_Configuration_Example
Here you have a link for Routed Mode and a sample for that:
http://docwiki.cisco.com/wiki/Basic_Load_Balancing_Using_Routed_Mode_on_the_Cisco_Application_Control_Engine_Configuration_Example
Then as you could see in all those links you may end up having a configuration like this:
interface vlan 40
  description "Default gateway of real servers"
  service-policy input remote-access
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.1.1
class-map match-all slb-vip
  2 match virtual-address 172.16.1.100 any
policy-map multi-match client-vips
  class slb-vip
    loadbalance vip inservice
    loadbalance policy slb
policy-map type loadbalance http first-match slb
  class class-default
    serverfarm web
serverfarm host web
  rserver lnx1
    inservice
  rserver lnx2
    inservice
  rserver lnx3
    inservice
rserver host lnx1
  ip address 192.168.1.11
  inservice
rserver host lnx2
  ip address 192.168.1.12
  inservice
rserver host lnx3
  ip address 192.168.1.13
  inservice
Please mark it if it answered you question then other users can use it as reference in the future.
Hope this helps!
Jorge
Jorge Bejarano
Level 4
Level 4
Carl,
Did everything go well?
Jorge
Cesar Roque
Level 4
Level 4
Hi Carl,
Do you have a Cisco Loadbalance like ACE or CSS?
If not, your probably wants to contact your Cisco Account Manager or Cisco System Engineer and they can give you the options based on your needs.
Cesar R
ANS Team
--------------------- Cesar R ANS Team
