ACE 4710 Pls need help
3225925
Pls can you help me find out where is my error in the below:
I have an ACE 4710. Also I have 2 Bluecoat Proxy SG working in proxy mode. I want the ACE to be the Load Balancer for these 2 Proxy SG. I configure the ACE as below and put the vip-address in the Internet Explorer LAN Settings but it did not work. Also I configure Policy-based Routing on the Core Switch (for any http or https traffic going through core apply set ip next-hop vip-address).
Core SW SVI:
interface Vlan56
description BC Proxy
ip address 10.0.1.33 255.255.255.224
interface Vlan57
description ACE-LB-Alias
ip address 10.0.1.65 255.255.255.224
ACE 4710:
hostname VSS-ACE-BC-01
interface gigabitEthernet 1/1
  description Management
  speed 1000M
  duplex FULL
  switchport access vlan 101
  no shutdown
interface gigabitEthernet 1/2
  description User Side
  speed 1000M
  duplex FULL
  switchport access vlan 56
  no shutdown
interface gigabitEthernet 1/3
  description BC Proxy Side
  speed 1000M
  duplex FULL
  switchport access vlan 57
  no shutdown
interface gigabitEthernet 1/4
  description Failover
  speed 1000M
  duplex FULL
  ft-port vlan 900
  no shutdown
context Admin
  member sticky
access-list external line 10 extended permit ip any any
access-list external line 20 extended permit icmp any any
access-list external line 30 extended permit tcp any any
access-list external line 40 extended permit udp any any
access-list internal line 10 extended permit ip any any
access-list internal line 20 extended permit icmp any any
access-list internal line 30 extended permit tcp any any
access-list internal line 40 extended permit udp any any
probe tcp web443
  port 443
  interval 30
  faildetect 1
  passdetect interval 30
  passdetect count 1
  open 1
probe tcp web8080
  port 8080
  interval 30
  faildetect 1
  passdetect count 1
  open 1
rserver host BC01
  ip address 10.0.1.41
  inservice
rserver host BC02
  ip address 10.0.1.42
  inservice
serverfarm host web443
  probe web443
  rserver BC01
    inservice
  rserver BC02
    inservice
serverfarm host web8080
  probe web8080
  rserver BC01
    inservice
  rserver BC02
    inservice
sticky ip-netmask 255.255.255.255 address source group1
  replicate sticky
  serverfarm web8080
sticky ip-netmask 255.255.255.255 address source group2
  replicate sticky
  serverfarm web443
class-map type management match-any REMOTE_ACCESS
  2 match protocol telnet any
  3 match protocol ssh any
  4 match protocol icmp any
  5 match protocol http any
  6 match protocol snmp any
class-map match-all external-web
  2 match virtual-address 10.0.1.70 any
class-map match-all external-web443
class-map match-any nat-class
  2 match access-list external
policy-map type management first-match REMOTE_MGMT
  class REMOTE_ACCESS
    permit
policy-map type loadbalance http first-match slb
  class class-default
    sticky-serverfarm group1
policy-map type loadbalance http first-match slb443
  class class-default
    sticky-serverfarm group2
policy-map multi-match external-access
  class nat-class
    nat dynamic 1 vlan 57
  class external-web
    loadbalance vip inservice
    loadbalance policy slb
  class external-web443
    loadbalance policy slb443
timeout xlate 120
interface vlan 56
  description Server-Side
  ip address 10.0.1.43 255.255.255.224
  ip verify reverse-path
  alias 10.0.1.40 255.255.255.224
  peer ip address 10.0.1.44 255.255.255.224
  mac-address autogenerate
  access-group input internal
  service-policy input REMOTE_MGMT
  no shutdown
interface vlan 57
  description VIP-Interface
  ip address 10.0.1.67 255.255.255.224
  alias 10.0.1.66 255.255.255.224
  peer ip address 10.0.1.68 255.255.255.224
  access-group input external
  service-policy input external-access
  no shutdown
interface vlan 101
  ip address 10.220.1.131 255.255.255.0
  alias 10.220.1.133 255.255.255.0
  peer ip address 10.220.1.132 255.255.255.0
  no shutdown
ft interface vlan 900
  ip address 172.20.100.1 255.255.255.252
  peer ip address 172.20.100.2 255.255.255.252
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 20
  ft-interface vlan 900
ft group 1
  peer 1
  priority 200
  peer priority 150
  associate-context Admin
  inservice
ip route 0.0.0.0 0.0.0.0 10.0.1.65
ajayku2
I see that you used:
Where is the nat pool on Vlan 57 ?
May be you can try to assign that and that should help.
Something like below:
Interface vlan 57
nat-pool 1 10.0.1.93 10.0.1.93 netmask 255.255.255.224 pat
regards,
Ajay Kumar
