ACE 4710 resource allocation issue
asepiacci
        HI,
I cannot understand the resource allocation of the ACE I have configured, in particular why the MAX allocation is lower than the MIN allocation, or even 0.
Probably, it's related to the RC0 class, where the maximum is set as unlimited, but I expected every context to have the maximum allocation equal to the class it belongs to. The only exception should be the Context D, the one associated to RC0 class, that could have a maximum of 54% = 30%(the minimum) + 24% (100% - 76% that is the sum of the minimum of all other contexts) .
This is the resource configuration:
ACE4710-O1-PRI/Admin# show run
resource-class RC0
  limit-resource all minimum 30.00 maximum unlimited
resource-class RC1
  limit-resource all minimum 10.00 maximum equal-to-min
  limit-resource sticky minimum 10.00 maximum equal-to-min
resource-class RC2
  limit-resource all minimum 20.00 maximum equal-to-min
  limit-resource sticky minimum 20.00 maximum equal-to-min
resource-class RC3
  limit-resource all minimum 5.00 maximum equal-to-min
  limit-resource sticky minimum 5.00 maximum equal-to-min
resource-class RC4
  limit-resource all minimum 1.00 maximum equal-to-min
  limit-resource sticky minimum 1.00 maximum equal-to-min
context A
  allocate-interface vlan 27
  allocate-interface vlan 324
  allocate-interface vlan 605
  allocate-interface vlan 607
  member RC2
context B
  allocate-interface vlan 603
  allocate-interface vlan 606
  member RC1
context C
  allocate-interface vlan 192-193
  allocate-interface vlan 251
  member RC3
context D
  allocate-interface vlan 388-389
  member RC0
context E
  allocate-interface vlan 608-609
  member RC4
context F
  member RC1
This is the actual resource usage and allocation:
ACE4710-O1-PRI/Admin# show resource usage
                                                     Allocation
        Resource         Current       Peak        Min        Max       Denied
Context: A
  conc-connections          11439      12244     400000          0          0
  mgmt-connections             44         46      20000          0          0
  proxy-connections         11439      12244      52429          0          0
  xlates                        0          0      13107          0          0
  acc-connections               0          0       2000          0          0
  bandwidth               3413889   21806480   26843400  125000000          0
    throughput            3413213    5408647   26843400          0          0
    mgmt-traffic rate         676        676          0  125000000          0
  connection rate              59         85     200000          0          0
  ssl-connections rate         50         79       1000          0    5238386
  mac-miss rate                 0          0        400          0          0
  inspect-conn rate             0          0       8000          0          0
  http-comp rate          2075434    4143487   13107200          0   21746221
  acl-memory                16712      16712    7508336          0          0
  sticky                       10         10     163840          0          0
  regexp                    10138      10138     209715          0          0
  syslog buffer            208896     208896     208896          0          0
  syslog rate                   1          3      20000          0          0
Context: B
  conc-connections            164       5571     200000          0          0
  mgmt-connections              0         32      10000          0          0
  proxy-connections           164       5571      26214          0          0
  xlates                        0          0       6554          0          0
  acc-connections               0          0       1000          0          0
  bandwidth                 56475    4014023   13421700  125000000        648
    throughput              53655    4001175   13421700          0        648
    mgmt-traffic rate        2820      12848          0  125000000          0
  connection rate               9       5847     100000          0          0
  ssl-connections rate          7        201        500          0          0
  mac-miss rate                 0          1        200          0          0
  inspect-conn rate             0          0       4000          0          0
  http-comp rate                0          0    6553600          0          0
  acl-memory                12896      12912    3753136          0          0
  sticky                       15         15      81920          0          0
  regexp                     1314       1314     104858          0          0
  syslog buffer            105472     208896     104448          0          0
  syslog rate                   0         53      10000          0          0
Context: C
  conc-connections              6        436     100000          0          0
  mgmt-connections              0         30       5000          0          0
  proxy-connections             4         41      13107          0          0
  xlates                        0          0       3277          0          0
  acc-connections               0          0        500          0          0
  bandwidth                   176     857478    6710850  125000000          0
    throughput                 90     841826    6710850          0          0
    mgmt-traffic rate          86      15652          0  125000000          0
  connection rate               0       6298      50000          0          0
  ssl-connections rate          0         19        250          0          0
  mac-miss rate                 0        200        100          0        979
  inspect-conn rate             0          0       2000          0          0
  http-comp rate                0          0    3276800          0          0
  acl-memory                16576      16592    1875504          0          0
  sticky                        1          3      40960          0          0
  regexp                     1062       1062      52429          0          0
  syslog buffer                 0          0      52224          0          0
  syslog rate                   0          0       5000          0          0
Context: D
  conc-connections           7124      18425     600000     480000          0
  mgmt-connections              8         70      30000      24000          0
  proxy-connections          7124      18421      78643      62914          0
  xlates                        0          0      19661      15728          0
  acc-connections               0          0       3000       2400          0
  bandwidth               4971240   16084230   40265100  157212080          0
    throughput            4971140   16079538   40265100   32212080          0
    mgmt-traffic rate         100       4692          0  125000000          0
  connection rate             126        844     300000     240000          0
  ssl-connections rate        117        855       1500       1200          0
  mac-miss rate                 0        109        600        480          0
  inspect-conn rate             0          0      12000       9600          0
  http-comp rate                0          0   19660800   15728640          0
  acl-memory
                24400      24416   11263536    9012511          0
  sticky                     3399       6713     245760          0          0
  regexp                     2438       2438     314573     251658          0
  syslog buffer                 0          0     314368     253952          0
  syslog rate                   0          0      30000      24000          0
Context: E
  conc-connections              0         16      20000          0          0
  mgmt-connections              2         44       1000          0          0
  proxy-connections             0          4       2621          0          0
  xlates                        0          0        655          0          0
  acc-connections               0          0        100          0          0
  bandwidth                   262      79518    1342170  125000000          0
    throughput                 90      72846    1342170          0          0
    mgmt-traffic rate         172       6672          0  125000000          0
  connection rate               2         10      10000          0          0
  ssl-connections rate          0          0         50          0          0
  mac-miss rate                 0          0         20          0          0
  inspect-conn rate             0          0        400          0          0
  http-comp rate                0          0     655360          0          0
  acl-memory                24272      24272     373424          0          0
  sticky                        0          7       8192          0          0
  regexp                      914        914      10486          0          0
  syslog buffer                 0          0      10240          0          0
  syslog rate                   0          0       1000          0          0
Context: F
  conc-connections              0          0     200000          0          0
  mgmt-connections              0          0      10000          0          0
  proxy-connections             0          0      26214          0          0
  xlates                        0          0       6554          0          0
  bandwidth                     0          0   13421700  125000000          0
    throughput                  0          0   13421700          0          0
    mgmt-traffic rate           0          0          0  125000000          0
  connection rate               0          0     100000          0          0
  ssl-connections rate          0          0        500          0          0
  mac-miss rate                 0          0        200          0          0
  acl-memory                 6976       7040    3753136          0          0
  sticky                        0          0      81920          0          0
  regexp                      914        914     104858          0          0
  syslog buffer                 0          0     104448          0          0
  syslog rate                   0          0      10000          0          0
This is the show ver:
ACE4710-O1-PRI/Admin# show ver
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 1985-2009 by Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  loader:    Version 0.95
  system:    Version A3(2.3) [build 3.0(0)A3(2.3) adbuild_16:41:21-2009/07/23_/auto/adbu-rel2/rel_a3_2_3_throttle/REL_3_0_0_A
3_2_3]
  system image file: (hd0,1)/c4710ace-mz.A3_2_3.bin
  Device Manager version 1.2 (0) 20090702:2137
  installed license: ACE-AP-VIRT-020 ACE-AP-C-500-LIC ACE-AP-OPT-LIC-K9 ACE-AP-SSL-05K-K9
Hardware
  cpu info:
    Motherboard:
        number of cpu(s): 2
    Daughtercard:
        number of cpu(s): 16
  memory info:
    total: 6226388 kB, free: 4129876 kB
    shared: 0 kB, buffers: 23172 kB, cached 0 kB
  cf info:
    filesystem: /dev/hdb2
    total: 861668 kB, used: 729204 kB, available: 88692 kB
last boot reason:  Unknown
configuration register:  0x1
ACE4710-O1-PRI kernel uptime is 435 days 15 hours 36 minute(s) 40 second(s)
Thanks.
Alessandro
Kanwaljeet Singh
Hi Alessandro,
I came across this document. Good read to understand resource allocation.
          Understanding Throughput Allocation on the ACE
`show resource usage all`
                                                     Allocation
Context: Admin
  bandwidth                   794      62282   75000000  200000000          0
    throughput                177       3183   75000000   75000000          0
    mgmt-traffic rate         617      59099          0  125000000          0
Context: CTX1
  bandwidth             357573782  425023811   50000000  550000000 3343868110
    throughput          357569156  425000000   50000000  425000000 3343868110
    mgmt-traffic rate        4626      23811          0  125000000          0
The above was taken from an ACE licensed for 4 Gbps of throughput.  There are
only two contexts configured on the ACE and they are each a member of a
unique resource-class.
resource-class RC-Admin
  limit-resource all minimum 15.00 maximum equal-to-min
resource-class RC-CTX1
  limit-resource all minimum 10.00 maximum unlimited
In order to see how the Min and Max allocations above correlate to 4 Gps, we
have to keep in mind that the numbers above are in bytes, not bits.
We can see from the resource-class configurations above that 25% of the bandwidth
is reserved for the two contexts (15% for the Admin context and 10% for CTX1).
     Admin Context:
     Admin context min alloc.             75,000,000     bytes
     Multiply by 8 to convert to bits            x 8     bits-per-byte
     Admin context min Total bps            600,000,000   bps (or .6 Gbps)
     CXT1 Context:
     CTX1 context min alloc.                   50,000,000     bytes
     Admin context min Total bps              400,000,000   bps (or .4 Gbps)
     Admin context min alloc.            600,000,000   bps (or .6 Gbps)
     CTX1 context min alloc.                 +  400,000,000   bps (or .4 Gbps)
     Total min allocated bps               1,000,000,000   bps (or 1 Gbps)
Notice that 1 Gbps is 25% of 4 Gbps, which is the aggregate of the minimum
throughput allocations for both contexts.
Now we move on to see how the remaining 3 Gbps is carved out for the two contexts
to use.
We can see from the resource-class configurations that the Admin context's
maximum throughput allocation is equal-to-min.  Therefore, it cannot use anymore
than its 15%, or .6 Gbps (or 600 Mbps).  The CXT1 context has a maximum throughput
allocation of unlimited, therefore it has access to all the remaining bandwidth on
the ACE, if necessary.
Since its maximum is shown as 425,000,000 bytes, we can see how this works out to
the remaining 3 Gbps as shown below:
     CTX1 context max alloc.                 425,000,000     bytes
     Subtract the min alloc.                   - 50,000,000     bytes
     Total remaining bytes available            375,000,000     bytes
     Total bps remaining in shared pool     3,000,000,000   bps (or 3 Gbps)
Now you can see how we've accounted for the 4 Gbps:
                              4,000,000,000     bps (or 4 Gbps)
In the output at the top of this document, you can see the throughput denies
on CTX1.  Since there is a minimum of .4 Gbps allocated to this context, plus
another 3 Gbps in the shared pool available if needed, CTX1 has access to a total
of 3.4 Gbps of throughput.  A chart sent by the customer indicated the throughput
on the ACE was peaking at roughly 3.8 Gbps during peak hours, thereby causing the
bandwidth denies.
Solution:
     In this case there are two options.
     1. There is currently 15% of resources allocated to the Admin context.
        Since the Admin context is only using a small fraction of this, it
        could be lowered to 2%, which would add another 510 Mbps of throughput
        to the shared pool.  This would bring the throughput that CXT1 has
        access to from 3.4 Gbps to 3.91 Gbps.  Since your peak is roughly
        3.8 Gbps, this would give you approximately 110 Mbps extra.
          NOTE:  Resources freed from one context, so another context can use
            them, can only be used by the new context if the first context
            is not using them.  Resources must be free in order for them
            to be transfered.
     2. At this point, a better long-term solution would be to upgrade the
        4 Gbps license to a 8 Gbps license.
Kanwal
Thanks Fnu for your kind reply, but if you have a look at the "show resource usage" I posted, you can see some values I can't understand. Focusing on ssl-connections:
Context A has a MIN = 1000, while MAX is 1000
Context B has MIN = 500 and MAX = 0
Context C has MIN = 250, and MAX = 0
Context D MIN = 1500 > MAX = 1200 and so on:
how is it possible?
And it's the same for other variables: the MAX column is 0 while MIN is "something" (or MIN > MAX).
I really can't understand.
