ACE 4710 send Connection:Close when should be Keep-Alive
drew mcclellan
After user request to front end http to 10.85.10.4 (default 80) after a port redirect and action list header rewrite
header rewrite request host header-value http://10[.]85[.]10[.]4 replace http://10.85.10.67:84/jde/E1Menu.maf%1
I see the request go out (wireshark) to the back-end javaserver but in the Connection it's close not keepalive:
GET /jde/E1Menu.maf HTTP/1.1
Connection: Close
Host:10.85.10.67:84
After the get from the ACE the jserver replies with the JDE login screen but the ACE ignores it?
Surya ARBY
Level 4
Level 4
Try by enabling persistence rebalance in an http parameter-map.
Also your rewrite rule is wrong, you've been mistaken regarding the role of the Host field I guess. What you try to configure in your config is a URL rewrite but it's not supported by the ACE.
