ACE 4710 - some applications are not running through ACE
shinde_hanu
Hi All,
I configured ACE 4710  for HTTP traffic. All applications are running through real server. But when I run the same applications from virtual IP i.e through ACE. some applications are not running. Particularly applications having XML.
Is it ACE issue or Application issue. If it is ACE issue then how to troubleshot.
Hanumant
mwinnett
Level 3
Level 3
Can you share some config and explananation of what is not working ? Matthew
