ACE 4710 SSL connection rate
dlance
What exactly happens when the SSL connection rate is exceeded. Is the connection dropped, queued or what ?
Defined as the SSL TPS. In our case 1000 but upgradeable to 5000
ajayku2
The connection will be denied once the SSL connection rate is exceeded.
That can be identified by using the command :
show resource usage all
You will see something like this :
        Resource         Current       Peak        Min        Max       Denied
ssl-connections rate        995       1000          0       1000     28975
You will notice that the deny counter will start increasing once the rate is exceeded.
hope that helps.
regards,
Ajay Kumar
OK but what will the user see. An error message  or lack of response ?
This connection will be dropped hence the usual message saying unable to connect to the webpage. It is almost like service is not available.
regards,
Ajay Kumar.
