ACE and Oracle Web logic
bmcginn
Level 3
Level 3
Hi All,
I have here a 6509-E chassis with a Sup720 in it and an ACE module also in it.
Our enviornment is getting oracle web-logic virtual servers via OVM.  Our ERP team would like to be able to load-balance to the web servers located in the oracle OVM box.  The Oracle OVM stuff, as near as I can make out uses java processes to direct traffic once it hits the box to the virtual web servers it contains. The java processes listen on different ports, thereby meaning there can be loads of web servers on the one box assuming the physical box has enough resources.
That said, I currently have three web servers all sitting on the one physical box.
For example:
server1 = http://10.1.95.70:9999
server2 = http://10.1.95.70:9888
server3 = http://10.1.95.70:9777
The Company bought ACE modules a while ago and we'd like to be able to use them to load balance across the three servers (there are a lot more than three but this illustrates the point).
In the configuration of the ACE module, the rserver mode (real server) requires an IP to be assigned to the rserver, this is the real IP address of the actual server and is classes as 'serverside' I think:
eg
rserver host SVR_9999
  description Real Server 9999
  ip address 10.1.95.70
  inservice
As the second web server also resides on that same IP, should it not also have the same IP?  ie
rserver host SVR_9888
  description Real Server 9888
  inservice
When I try to enter in the ip address however it errors out with a duplicate:
ACE1/TEST_CTX(config)# rserver host SVR_9888
ACE1/TEST_CTX(config-rserver-host)# ip address 10.1.95.70
Error: Duplicate IP address or subnet
My question is:  Is there a way I can use the ACE module to load balance to different web servers on the one IP address (assuming the rest of the configuration is fine)?   Something that would achieve the following eg?
  ip address 10.1.95.70:9999
  inservice
  ip address 10.1.95.70:9888
  inservice
Many thanks in advance.
Brad
Hi Bmcqinn,
I understand from your diagram you have one server with one application on three different port and you want to one VIP to load balance between different ports not different real IPs, if this is the scenario off course you can do this.
create one rserver
creater one server server, define rserver with multiple port
-----Configuration starts------------------
rserver host SVR_1
    inservice
serverfarm host SRV_Web_logic
    rserver SVR_1 9999
      inservice
    rserver SVR_1 9808
       inservice
    rserver SVR_1 9806
       inservice
sticky ip-netmask 255.255.255.255 address both STICKY_Web_logic
  timeout 510
  replicate sticky
  serverfarm SRV_Web_logic
class-map match-all VIP_Web_logic
  2 match virtual-address 10.1.103.10 tcp eq 80
policy-map type loadbalance first-match SLB_Web_logic
  class class-default
    sticky-serverfarm STICKY_Web_logic
policy-map multi-match ORACLE
  class VIP_Web_logic
    loadbalance vip inservice
    loadbalance policy SLB_Web_logic
    loadbalance vip icmp-reply
interface vlan 203
   ip address 10.1.103.1 255.255.255.0
     service-policy input  ORACLE
-----Configuration Ends------------------
vashdevt
You need to create one rserver and multipul serverfams with port number as follow.
rserver host SVR_1
  inservice
rserver host SVR_2
  inservice
serverfarm host SRV_9999
    rserver SVR_1 9999
      inservice
    rserver SVR_2 9999
       inservice
serverfarm host SRV_9888
    rserver SVR_1 9888
       inservice
    rserver SVR_2 9888
       inservice
serverfarm host SRV_9777
    rserver SVR_1 9777
       inservice
    rserver SVR_2 9777
       inservice
sticky ip-netmask 255.255.255.255 address both STICKY_9999
  timeout 510
  replicate sticky
  serverfarm SRV_9999
sticky ip-netmask 255.255.255.255 address both STICKY_9888
  timeout 510
   replicate sticky
   serverfarm SRV_9888
sticky ip-netmask 255.255.255.255 address both STICKY_9777
  timeout 510
   replicate sticky
   serverfarm SRV_9777
class-map match-all VIP_9999
  2 match virtual-address xxx.xxx.xxx.xxx tcp eq 9999
class-map match-all VIP_9888
   2 match virtual-address xxx.xxx.xxx.xxx tcp eq 9888
class-map match-all VIP_9777
   2 match virtual-address xxx.xxx.xxx.xxx tcp eq 9777
policy-map type loadbalance first-match SLB_ORACLE_9999
  class class-default
    sticky-serverfarm SRV_9999
policy-map type loadbalance first-match SLB_ORACLE_9888
   class class-default
     sticky-serverfarm SRV_9888
policy-map type loadbalance first-match SLB_ORACLE_9777
   class class-default
     sticky-serverfarm SRV_9777
  class VIP_9999
    loadbalance policy SLB_ORACLE_9999
  class VIP_9888
    loadbalance policy SLB_ORACLE_9888
  class VIP_9777
    loadbalance policy SLB_ORACLE_9777
interface vlan xx
   ip address yyy.yyy.yyy.yyy 255.255.255.0
Vashdev
Hi Vashdev,
Thanks for the reply!
I should have mentioned that I'm trying to get the load balancing working one one specific VIP.  I've attached a diagram which will hopefully shed a bit more light.
If the ACE can't do this, does any Cisco person in the CSC have any idea if it will be anytime soon?
Brad
Hi Bmcqinn,
create one rserver
rserver host SVR_1
    inservice
    rserver SVR_1 9999
      inservice
    rserver SVR_1 9808
       inservice
    rserver SVR_1 9806
       inservice
  timeout 510
  replicate sticky
  class class-default
  class VIP_Web_logic
interface vlan 203
Vashdev,
Mate you're a champion.  It looks to be working now.
Thanks very much for your help, I appreciate it greatly!
Brad
