ACE bridge mode config not working
raza555
Level 3
Level 3
I have attached ACE30 configuration, I am unable to establish connection to the VIP.
From the ACE: I can see the ARP of all servers and VIPS. I can ping GW,Server & VIP.
From 6500 Switch: I cannot see the ARP of Servers, VIP & GW. I am only able to ping the servers(164.x.x.106/107), but not the ACE contect VIP (164.x.x.103) or GW (164.x.x..101)
From FWSM:I can ping GW,Server but not the VIP. Rules allow for ping/443 from outside and firewall is acting as transparent firewall.
Any help will be very much appreciated.
2 Accepted Solutions
Kanwaljeet Singh
Hi Rizwan,
You have mentioned ACE in bridge mode but according to the configuration it seems to be in the routed mode. Kindly check on the  toplogy. The configuration on ACE looks fine. Ensure that proper routing is in place.
Kanwal
Note: Please mark answers if they are helpful.
Hi Rizwan,
I don't know your topology. But if  the real server gateway is not loadbalancer, the return traffic will not go through the LB and it will be a problem due to asymmetric routing. To avoid that you would need to do source natting on LB so that return traffic comes back to ACE or you can have routing on the server itself but normally the best option is to do source natting or make ace as your default gateway.
Let me know if you have any questions.
Kanwal
Kanwaljeet Singh
Hi Rizwan,
Kanwal
Hello kanwal,
Thanks for advise, its a routing issue. Please advise that what should be the default gateway of the server as per my attached ACE config.
Thanks.
Hi Rizwan,
Kanwal
Thanks again Kanwal,
1) Server DG gateway should be ACE interface IP Address or its VIP IP Address?
2) Can I access the server individual IP Address as well?
