ACE - bridged mode - blocking Traffic
pat1848
Just a short question. Is an ACE blocking traffic from a Source if the mac-address of that source is not in the ARP/MAC table? No security feature is enabled. The sniffer shows, that the packet is not going through. Other traffic works fine. So no problem with incoming ACL or something else. Any reason for that.
Cheers
patrick
pat1848
Any suggestions?
Cheers
patrick
By default, for bridged traffic, the ACE learns MAC addresses from all traffic.
What is the source address in your case?
Is it a default gateway?
If it is then create a dummy real server using gateway IP address. This way ACE will pro actively populate the ARP table and ARP entry will never time out.
Syed Iftekhar Ahmed
Gilles Dufour
Patrick,
indeed, if the src mac is not in the arp table, we can't setup a flow entry for that traffic and it is dropped.
We should first learn the mac-address from arp traffic.
Also check the following command to see if that helps:
switch/Admin(config-if)# arp inspection validate src-mac ?
flood Enable the flood option
no-flood Enable the no flood option
Carriage return.
Gilles.
