ace transaparent mode-return traffic
followurself
Level 5
Level 5
we have fwsm running in routed mode and behind it is the ace. the ace is in bridge mode.we try to connect a sever ove http and see a connection hitting fwsm and then the ace. in ace we can see a return packet from the serverfarm host but then the return packet isnt seen on fwsm. we can ping the server directly hence no routing issues.looks like ace isnt sending the traffic back. below is the config with outputs of show conn from ace and fwsm and show policy of ace
any help will be appreciated
thanks
probe http cer_port
port 9005
interval 5
faildetect 15
passdetect interval 15
receive 2
expect status 200 200
open 2
serverfarm host SFarm3
probe cer_port
rserver ZHC1 9005
inservice
rserver ZHC2 9005
inservice
rserver ZHC3 9005
inservice
sticky http-cookie acecookie sticky-cookie-insert_9005
cookie insert
replicate sticky
serverfarm SFarm3
class-map match-all ACL
2 match access-list FW_Controlled
class-map match-all forms_listener_port_9000
2 match virtual-address 10.7.20.6 tcp eq 9000
policy-map type loadbalance f9000_policy
class class-default
sticky-serverfarm sticky-cookie-insert_9005
policy-map multi-match VIPS
class fot_9000
loadbalance vip inservice
loadbalance policy f9000_policy
loadbalance vip icmp-reply active
ace1-pri/# sh conn
total current connections : 2
conn-id np dir proto vlan source destination state
15 2 in TCP 720 Mx:2954 10.7.20.6:9000 ESTAB
16 2 out TCP 720 10.7.20.21:9005 Mx:1037 INIT
fw-pri/prod# sh conn
TCP out Mx:2960 in 10.x.x.6:8000 idle 0:00:03 Bytes 1692 FLAGS - UBI
show service-policy
Policy-map : VIPS
Status : ACTIVE
Interface: vlan 7xx 7x1
service-policy: VIPS
class: web_xxxxxxxx_8000
loadbalance:
L7 loadbalance policy: web_xxxxxx0_policy
VIP Route Metric : 77
VIP Route Advertise : DISABLED
VIP ICMP Reply : DISABLED
VIP State: INSERVICE
curr conns : 1 , hit count : 26
dropped conns : 23
client pkt count : 62 , client byte count: 14411
server pkt count : 0 , server byte count: 0
interface vlan 7xx
description interface facing Servers
bridge-group 1
access-group input BPDU
access-group input all
service-policy input VIPS
no shutdown
interface vlan 7xx
description interface facing FWSM
bridge-group 1
no shutdown
29 Replies 29
followurself
Level 5
Level 5
seems ace is not sending traffic back to fwsm
any ideas
Since your post doesn't give detail about class fot_9000 (which i sused under service policy VIPS)I am curious if "service-policy VIPS" is really needed under both VLANs and if its causing some looop.
Syed Iftekhar Ahmed
Gilles Dufour
the status of the connection on the backend is init. You can also see server pkt count at 0.
So ACE didn't see the response on vlan 720.
Are you sure the packet comes back on the right vlan ???
Implement client nat and if it works you know it was an symetric routing issue.
Gilles.
class-map match-all fot_9000
interface bvi 1
ip address 10.7.20.3 255.255.255.0
peer ip address 10.7.20.4 255.255.255.0
no shutdown
Destination Gateway Interface Flags
0.0.0.0 10.7.20.1 vlan720 S
10.7.20.0/24 0.0.0.0 bvi1 IA
vlan 720 is server side facing vlan and vlan 770 is fwsm side
ip 10.7.20.1 is basically fwsm ip and also the gateway for all servers
Friends
config may create confusion,apologies
pls replace 9000 with 8000
thanks
and also 9005 to 8005
Friends
class: web_listener_port_8000
VIP Address: Port:
10.7.20.6 eq 8000
loadbalance:
L7 loadbalance policy: web_listener_port_8000_policy
curr conns : 1 , hit count : 42
dropped conns : 39
client pkt count : 98 , client byte count: 25323
L7 Loadbalance policy : web_listener_port_8000_policy
class/match : class-default
LB action :
hit count : 35
dropped conns : 0
also the drop counts keeps increasing. i m not sure where the packet is going
Get a sniffer trace and follow the response.
That's all you can do.
ACE does not see any response and drops the connection marking it as a conn_failure.
Gilles.
Thanks Giles
is there any config issue, service policy in paticular?
the design is standard
msfc--fwsm (routed mode and gateway for all servers) - ace (bridge mode) -- hp enclosure (layer 2 trunk back to msfc)
i can ping the servers directly. will my ping pass thru ace?
can see all the arp in ace for the servers
The config looks ok and the ping is not enough to guarantee there is no asymetry.
You will need to get a sniffer trace.
G.
do i need service policy input VIPS on my bridge interfaces looking at the class
when you said client nat can you please help with the config
the servers are teamed with transmit load balancing. this infrastructure is remotely located, i can only sniff the servers as of now
Giles i appreciate if you can help me with the traffic flow please
client---msfc/pfc---fwsm (gateway)---ace (bridgemode)---hp switches---servers
when traffic comes from client it hits msfc, thn to fwsm..fwsm does a static nat for the vip address and sends it to ace. ace receives and sends it to severs..here ace will send it via msfc--to hp--then to severs. all servers default gateway is fwsm. my ip is 10.1.102.232 and server 10.7.20.21, within ace con table we can see a conn intiated by ace with source as 10.1.102.232 and dst 10.7.20.21 ..but when client replies it will send the traffic to fwsm (default gateway) how wil this be intercepted by ace. i guess the arp wd be of ace
Giles
I applied client nat on interface 720 (facing servers) and policy only on tht interface and it worked
but i dont want to use the client nat? i m going to sniff the sever
i did a capture on fWSM which is the gateway of servers
my design is msfc-fwsm(routed mode)--ace (bridgemode) -hp enclosure where servers are located
looks like the server do respond and they hit their gateway and its not intercepted by ACE
with the above design and no client how can we make it work..pls help
show capture tin detail
14 packets seen, 12 packets captured
1: 13:55:32.1301371320 001e.bed7.5100 000b.fcfe.1b02 0x8100 66: 802.1Q vlan#7
20 P0 10.1.102.232.3012 > 10.7.20.6.8000: S [tcp sum ok] 2354942469:2354942469(0
) win 64512 (DF) (ttl 118, id 38224)
2: 13:55:32.1301371320 000b.fcfe.1b02 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
20 P0 10.7.20.6.8000 > 10.1.102.232.3012: S [tcp sum ok] 1745154344:1745154344(0
) ack 2354942470 win 17408 (ttl 255, id 30819)
3: 13:55:32.1301371340 001e.bed7.5100 000b.fcfe.1b02 0x8100 64: 802.1Q vlan#7
20 P0 10.1.102.232.3012 > 10.7.20.6.8000: . [tcp sum ok] 2354942470:2354942470(0
) ack 1745154345 win 65520 (DF) (ttl 118, id 38226)
4: 13:55:32.1301371340 001e.bed7.5100 000b.fcfe.1b02 0x8100 690: 802.1Q vlan#
720 P0 10.1.102.232.3012 > 10.7.20.6.8000: P 2354942470:2354943102(632) ack 1745
154345 win 65520 (DF) (ttl 118, id 38227)
5: 13:55:32.1301371340 000b.fcfe.1b02 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
20 P0 10.7.20.6.8000 > 10.1.102.232.3012: . [tcp sum ok] 1745154345:1745154345(0
) ack 2354943102 win 17408 (ttl 255, id 30811)
6: 13:55:32.1301371340 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
20 P0 10.7.20.21.8005 > 10.1.102.232.1079: S [tcp sum ok] 2563662798:2563662798(
0) ack 659054809 win 5840 (DF) (ttl 64, id 0)
7: 13:55:35.1301374250 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
8: 13:55:36.1301375140 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
9: 13:55:41.1301380070 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
10: 13:55:42.1301381140 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
11: 13:55:53.1301391720 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
12: 13:55:54.1301393340 001f.296a.860c 001e.bed7.5100 0x8100 64: 802.1Q vlan#7
