ACE Complex Design
helsayed78
Level 3
Level 3
Guys,
I am facing some problems with my ACE design and would like or thoughts and feedback on this:
  • I have an ACE with a client side and a Server Farm interface.
  • The client side layer 3 interfaces resides on the core backbone and the Server Farm layer 3 interface is behind a Firewall.
  • We have a two other servers load balanced located in the server farm and loadbalaced using Cisco ACE ( using a VIP Client Side IP).
Here is what we are facing:
The load balancing is working correctly when traffic is coming from any other subnet other than the server farm.
In other words Loadbalancing is not working with VIP IP for servers that reside in the server farm since there is a serverfarm interface on the ACE.
Does anyone have a clue.
Hesham
10 Replies 10
ajayku2
Hi Hesham,
The solution is quite easy apply multimatch policy for the VIP in the serverfarm VLAN interface.
This will fix the issue.
When traffic hit the interface it match the class map and use the policy applied on that interface for loadbalancing.
Since you have not applied any policy on the server vlan interface it is not going to do any load balancing.
Hope it helps.
regards,
Ajay Kumar
You mean under the Server Farm VLAN ??  and what is the exact syntax that should be used?
Hesham
Here is the configuration:
class-map match-all Test-C1
  2 match virtual-address 172.X.X.X any
class-map type management match-any REMOTE-MGMT
  description ---------Enable remote access---------
  10 match protocol ssh any
  20 match protocol icmp any
  30 match protocol https any
policy-map type management first-match REMOTE-ACCESS
  class REMOTE-MGMT
    permit
policy-map type loadbalance first-match Test-POLICY
  class class-default
    sticky-serverfarm Test-Stickiness
policy-map multi-match SF-POLICY
  class Test
    loadbalance vip inservice
    loadbalance policy Test-POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 800
interface vlan 100
  description ---------SERVER SIDE INTERFACE--------
  ip address 172.X,X,X, 255.255.255.0
  alias 172.X,X,X, 255.255.252.0
  peer ip address 172.X,X,X, 255.255.252.0
  no normalization
  mac-sticky enable
  no icmp-guard
  access-group input ACL-IN
  nat-pool 1 172.X,X,X,X, 172.X,X,X,X netmask 255.255.252.0 pat
  service-policy input REMOTE-ACCESS
  no shutdown
interface vlan 200  description ---------CLIENT SIDE INTERFACE---------
  ip address 172.Y.Y Y. Y.255.255.255.0
  alias 172.Y.Y.Y.y 255.255.255.0
  peer ip address Y.Y.yYU 255.255.255.0
  no normalization
  no icmp-guard
  service-policy input Test-POLICY
  no shutdown
I am not sure why you have applied only
service-policy input Test-POLICY  <<< You should have applied mutimatch policy SF-POLICY >>
Something like this:
service-policy input SF-POLICY
So the solution is to apply:
interface vlan 100
Check and let me know if it helps.
regards,
Ajay Kumar
It is same as you have used in client VLAN interface.
Something like this
Admin(config-if)# service-policy input vippolicy
In case if you still have confusion attach the running config and let me know the VIP IP.
regards,
Ajay Kumar
could you send me your private email so I can send you the config file
I have seen your config in the above. I am trying to say that you should apply this line in following interface.
interface vlan 100
  no normalization
  mac-sticky enable
  no icmp-guard
service-policy input SF-POLICY  <<<<<< Type this line by going to interface 100 >>>>>>>
no shutdown
Do the testing and let me know if it works for you.
I did so and didn't work.
Two things to check:
1) Default gateway should point to ACE for this to work.
2) The return traffic from real server may be going to the server directly. Adding a NAT should fix this issue.
You can check the symptoms as shown below:
show conn | in ip address of server ( Acting as client)
See if connection is going to ACE or not.
See if the connection is getting load balanced or not.
If it is load balancing then the issue is real server is responding directly to server ( Client) and hence the connection is getting dropped. So add a NAT to fix the issue.
Cesar Roque
Level 8
Level 8
Hi Hesham,
You probably need a nat-pool to make it work, please send me the running config or showtech of the Context where you have this setup
--------------------- Cesar R ANS Team
