ACE connectivity with 6500
Deepak Chauhan
Can Anybody tell me, how the ACE is connected physically with the host switch 6500/7600 for data path?
Cheers,
Deepak
sumit menaria
Hi Deepak,
The ACE is inserted in a module in 6500.On connecting the module ,an interface is created ,which is of format TeX/1 ,where X is the module number.Also for the data path traffic we can define what all VLAN traffic should be forwarded to the the ACE we can define using following commands.
svclc module 3 vlan-group 1
svclc vlan-group 1  2-100,110,211-218,321,411-418
where module 3 is the slot number for the ACE.
Hope it helps.
Great day,
Sumit Menaria
