ACE FTP problem in active mode
marco.becu
Hi everyone,
i have a problem with active ftp (passive ftp works fine).
here is my conf :
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
rserver host ftp1
  ip address 10.0.151.131
  inservice
rserver host ftp2
  ip address 10.0.151.132
  inservice
serverfarm host ftp
  transparent
  failaction reassign
  rserver ftp1
    inservice
  rserver ftp2
    inservice
class-map match-any vip
  2 match virtual-address X.X.X.X tcp eq ftp
policy-map multi-match LBPOL
  class vip
    loadbalance vip inservice
    loadbalance policy lbpol
    loadbalance vip icmp-reply active
    inspect ftp
interface vlan 1000
  description public-side
  ip address Y.Y.Y.Y M.M.M.M
  no normalization
  no icmp-guard
  access-group input ANY
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  service-policy input LBPOL
  no shutdown
interface vlan 100
  description private-side
  ip address 10.0.99.160 255.255.0.0
  no shutdown
on both hosts, i added X.X.X.X vip and the good rule/route with iproute2.
as i said at the beginning, passive ftp is ok. active is not.
while in active mode, i can connect to the ftp but any list/put/get fails.
any idea ?
MA
6 Replies 6
Ivan Kovacevic
One thing I don't understand here is why do you have
serverfarm host ftp
  transparent
With this in place the ACE will not rewrite the destination IP and the server will receive a packet destined to the VIP. This is not very common, but it can work. The rest of your config seems to be fine, except the missing lbpol policy.
Which sw version are you running?
tx for answering.
transparent is to prevent my system to work with NAT.
  class vip
    inspect ftp strict
system:    Version A2(3.2) [build 3.0(0)A2(3.2)]
So your both servers are expecting traffic with destination IP X.X.X.X? That is what the transparent command will do.
And the part that is missing begine with the line
policy-map type loadbalance first-match lbpol
sorry, you are right :
  class class-default
    serverfarm ftp
=> yes.
got it
interface vlan 100
+  mac-sticky enable
  no shutdown
anyway tx Ivan
