ACE issue with traceroute
Ahmed Shahzad
Level 4
Level 4
ACE is load balancing on layer three devices. When trying to traceroute behind ACE does not showing any hop except ACE.
traceroute 58.27.191.17 source 192.168.25.6
Tracing the route to 58.27.191.17
1 192.168.25.137 0 msec 0 msec 0 msec
2 * * *
3 * * *
4 *
Shahzad.
Gilles Dufour
Configure icmp inspect error on all ace interfaces.
access-list 102 line 10 extended permit icmp any any
class-map match-all icmp_traffic
2 match access-list 102
policy-map multi-match icmp_inspect
class icmp_traffic
inspect icmp error
service-policy input icmp_inspect
Also be aware of
CSCsj64833-The network utility traceroute does not work for a configured ACE IP interface if the underlying protocol is UDP or TCP. Workaround: ICMP traceroute will work. The default of most traceroute utilities is UDP so a command line option might be necessary. For Linux, use the -I option.
Gilles Dufour
class icmp_traffic
inspect icmp error
Also be aware of
