ACE Load Balance by URL
joao.beca
Hello, It´s my first topic and I have a hard issue related with Cisco ACE.
We have a configuration load balancing a URL in the port 80 with no problems, but, with the port 443 is not working.
Both the probe, serverfarm and realservers are OK (active) but I don´t see any connection reaching ACE with HTTPS. With HTTP is OK.
Have anyone already had a issue like that? Is there a solution? I really appreciatte any help. Hugs
TIM JUDGE
Please post your configuration without including any identifying details so we can take a look, make sure you include your class map and policy maps. Best way to get a full config is to type "show run filter" followed by the name of the service policy you have applied to your interface. That should include all relevant config
Hello Tim, we solved the problem the last wekeend. The problme was the certificate that we had to pass to ACE, so we took out the certificate in the Apache server and download to ACE. Thanks at all.
