ACE Load lancing for various traffic pattern
sachin.patole
I have situation as where ACE is doing load balancing on 2 real servers for application traffic.
The requirement is that I want to use the same VIP & real server ( with same IP addresses )  for SFTP traffic.
But in this case I want to send traffic only 1 real server . In failure scenario when server 1 goes down traffic will be send to 2nd real server.( i.e. active /standby scenario).
Any suggestion how it can be done with affecting production application traffic ?
Sach
6 Replies 6
pablo.nxh
Level 3
Level 3
Hi Sachin,
If your current configuration is not using port translation under the serverfarm (rservers with specific port defined) then
you can use the same serverfarm for SFTP load balancing.
SFTP is just FTP over SSH so it's a straight configuration to load balance traffic on port 22.
You can try this config:
probe tcp SFTP
  port 22
  interval 5
  faildetect 2
  passdetect interval 5
  passdetect count 2
serverfarm host SFARM2
  probe SFTP
  rserver FTP-1
   backup-rserver FTP-2
    inservice
  rserver FTP-2
    inservice standby
class-map match-any VIP
  2 match virtual-address 10.10.10.100 tcp eq 22
policy-map type loadbalance first-match SFTP
  class class-default
    serverfarm SFARM1
policy-map multi-match Current
  class Current
    loadbalance vip inservice
    loadbalance policy SLB
    loadbalance vip icmp-reply active
  class VIP
    loadbalance policy SFTP
__ __
Pablo
Pablo,
Thanks for your reply.
As per your suggestion if 2nd server is inactive , so how it will carry traffic when 1st server goes down ?
~~Sachin
Hi Sachin,
If your primary rserver goes down due to probe failure all the connections associated with  that server will be automatically flushed from the connection table so that all new incoming connections will be diverted to your backup rserver.
Once the primary rserver comes back online then:
- Existing connections on backup keep accessing backup till they're completed.
- If a new client request (connection) doesn't match any connection entry for backup rserver ACE forwards this request to primary.
Once all the current conns on backup rserver are closed it returns to standby state.
Hope this clears things up!
__ __
Pablo
Hi Pablo,
I have following config for REAL server farm
serverfarm host OSBFARM
  rserver osbpla01-app 8017
    probe HTTP_8017
    inservice
  rserver osbpla01-app 8019
    probe HTTP_8019
    inservice
  rserver osbpla02-app 8017
    probe HTTP_8017
    inservice
  rserver osbpla02-app 8019
    probe HTTP_8019
    inservice
If I add following config under this server farm will it affect traffic for above config,
  probe SFTP
  rserver FTP-1
    inservice
  rserver FTP-2
    inservice standby
Sachin
Hi Sachin,
This should not affect your current SF configuration as this new serverfarm will be used under a different first-match service-policy regardless they use the same VIP address.
__ __
Pablo
