Help with Importing Certificates on ACE
bryankrausen
I have plenty of certs running on my ACE, but when trying to import som
e Verisign certs, I get the following message:
Failed to Deploy config to device: Configure device error: com.cisc.nm.lib.cmdsvc.ssh2.ssh2Exception. Please enable ssh for ACE by typing "ssh key rsa 1024" under config mode.
Is it really just that simple? Or am I missing something?
Telmo Pereira
Hello Bryan,  Can you tell us how you are trying to important certificates to your ACE?  Are you using ANM, or ACE CLI? In case you're running ANM which version are you using?  Is this error message showing consistently with only Verisign certficates? How many certificates  did you import before it failed?  There are a few bugs you might be hitting here, if you provide me these details I'll try to spot it out for you.   Regards,  Telmo
tonybourke
That's really all you need to do.  Type that command in, and you can import.  It's an issue with the GUI importing tool, it needs to run SSH (even if you're only doing FTP).
