ACE MIB Value for Fail over
Jithesh K Joy
     May I know the MIB value ACE (Application Contril Engine )will be generating  while a fail over occurs. Is the value same for contetx fail over as well ??
Jithesh
scott-goodwin
I think this is the error code your looking for;
727012
Error Message    %ACE-2-727012: HA: FT Group group ID changed state to NewState. Reason:
reason str.
Table 2-2 NewState Values and Descriptions
NewState Value
Description
FSM_FT_STATE_INIT
The initial state. Visible only when the configuration for the FT group exists but it is not in service.
FSM_FT_STATE_ELECT
After you enter the inservice command when you are configuring an FT group, the ACE enters the ELECT state. The redundancy state machine negotiates with its peer context in the FT group to determine the redundancy role (active or standby)
FSM_FT_STATE_ACTIVE
The active member of the FT group.
FSM_FT_STATE_STANDBY_COLD
This state can be entered if:
FT VLAN is down but the peer device is still alive.
Configuration or application state synchronization failure have occurred.
FSM_FT_STATE_STANDBY_CONFIG
The standby context is waiting to receive configuration information. Upon entering this state, the active context will be notified to send a copy of the running configuration.
FSM_FT_STATE_STANDBY_BULK
The standby context is waiting to receive state information. Upon entering this state, the active context will be notified to send a copy of the current states information for all applications.
FSM_FT_STATE_STANDBY_HOT
The standby context is ready to become active in a failover situation.
Values returned for the reason str variable can be one of the following:
FSM_FT_EV_PEER_DOWN
FSM_FT_EV_PEER_FT_VLAN_DOWN
FSM_FT_EV_PEER_SOFT_RESET
FSM_FT_EV_STATE
FSM_FT_EV_TIMEOUT
FSM_FT_EV_CFG_SYNC_STATUS
FSM_FT_EV_BULK_SYNC_STATUS
FSM_FT_EV_COUP
FSM_FT_EV_RELINQUISH
FSM_FT_EV_TRACK_STATUS
FSM_FT_EV_UPDATE
FSM_FT_EV_ENABLE_INSERVICE
FSM_FT_EV_DISABLE_INSERVICE
FSM_FT_EV_SWITCHOVER
FSM_FT_EV_PEER_COMPATIBLE
FSM_FT_EV_MAINT_MODE_OFF
FSM_FT_EV_MAINT_MODE_PARTIAL
FSM_FT_EV_MAINT_MODE_FULL
Check from the above ID onwards for more details around ft status.
Cheers
Scott
