ACE MIBs Issue
soliver2005
I have identified a number of MIBs that I want our OSS systems to use to collect performance data relating to our ACE (ACE20-MOD-K9 running 30.(0)A2(1.6a)).  I have identified the MIBS from the CISCO-SLB-MIB and the CISCO-ENHANCED-SLB-MIB but when our OSS Systems try to do an SNMP Walk on the ACE for these MIBs nearly all of them come back with the following message -
"no MIB objects contained under subtree"
The MIBs I have tried are the following -
1.3.6.1.4.1.9.9.470.1.1.1.1.17
1.3.6.1.4.1.9.9.470.1.1.1.1.18
1.3.6.1.4.1.9.9.470.1.1.1.1.19
1.3.6.1.4.1.9.9.470.1.1.3.1.11
1.3.6.1.4.1.9.9.470.1.1.3.1.12
1.3.6.1.4.1.9.9.470.1.1.3.1.13
1.3.6.1.4.1.9.9.161.1.3.1.1.5
1.3.6.1.4.1.9.9.161.1.3.1.1.13
1.3.6.1.4.1.9.9.161.1.4.1.1.17
The only one that comes back with a value is shown below -
1.3.6.1.4.1.9.9.161.1.4.2.1.7
cisco.ciscoMgmt.161.1.4.2.1.7.2.48 : Counter: 1091236
Has anyone experienced something like this or have any ideas on where we are going wrong.  We have multiple Virtual Contexts configured and are trying to get the values from a specific context.
Stuart
amacuz
Good morning Stuart,
I do not know all the detail sof the configuration but what I can tell you is that in newer versions than A2(1.6a) there were some enhancement about the OIDs you report.
Please have a look at this document
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_2_x/release/note/RACEA2_2X.html
paragraph "Enhancements to the CISCO-ENHANCED-SLB-MIB".
You many need to replace cesRealServerStateUpwith cesRealServerStateUpRev1.
This translates into moving from 1.3.6.1.4.1.9.9.470.0.1 to 1.3.6.1.4.1.9.9.470.0.7.
You can use the Cisco "SNMP Object Navigator" available here:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
to translate all the options.
I would try a newer version and see if the situation improves.
Hope this helps,
Alessandro
If  this helps you and/or answers your question please mark  the question as  "answered" and/or rate it, so other users can easily  find it.
