ACE module https Probe operation question with nested request method
RAMAN AZIZIAN
Level 3
Level 3
Fellow Networkers,
Could someone kindly provide an explanation in regard to the https probe (standard https probe provided with ACE) operation?
What I'm trying to determine/uderstand is how does the ACE interpert the expected status code, since I am not terminating SSL in the ACE or is it even neccessary for me to include the expected status code.
When the probe is being applied, does the ACE look for the handshaking routine (client hello, etc) to built the session ID, and then sends an "get" to check the status code? I'm trying to understand if the ACE is not terminating the SSL, is the return code status encrypted or not encrypted.
One of our server admin would like to send an specific request, like the command below, and I wasn't sure if it would work. Unfortunatly i do not have a spare ACE module to do some testing.
request method head url /aims/enterprise/user
Example:
probe https generic-HTTPs
   interval 5
   passdetect interval 5
   receive 5
   expect status 200 405
serverfarm host generic-HTTPS
  predictor leastconns
  probe generic-HTTPs
  rserver RSRV1
    inservice
  rserver RSRV2
    inservice
If you need any additional information, please let me know.
raman
yushimaz
When you configure https probe on ACE, a connection is established between ACE and rserver
by 3 way handshake. And then ssl handshake is processed between ACE and rserver.
After receiving Finished message from rserver, ACE sends http request to rserver.
If you configure 'request method head url /aims/enterprise/user' on the probe generic-HTTPs,
this http request becomes head request.
If you configure 'expect status 200 405', ACE checks status code is valid. If you don't configure
'expect status' command, ACE only check whether status code is returned or not.
Since probe process works between ACE and rserver configured probe, you don't need 'ssl-proxy
service' config.
As an example, I attached capture trace of https probe with the following configuration.
I got this trace with NAM module on the same chassis and then filtered with tcp.port==443.
Since I also attached private key, you can decode the capture trace with wireshark.
http://wiki.wireshark.org/SSL
Edit -> Preference -> Protocols -> SSL
RSA key list: 192.168.72.254,443,http,c:\key_probe-ssl.pem
SSL debug file: c:\ssl_debug.txt
### config
ACE20a/Admin# sh run probe
Generating configuration....
probe https probe-ssl
  interval 5
  receive 5
  expect status 200 200
ACE20a/Admin#
ACE20a/Admin# sh run rserver
rserver host rserver-ssl
  ip address 192.168.72.254
  inservice
ACE20a/Admin# sh run serverfarm
serverfarm host sf-ssl
  probe probe-ssl
  rserver rserver-ssl
    inservice
Yuji
yushimaz
service' config.
### config
  interval 5
  receive 5
ACE20a/Admin#
  inservice
  probe probe-ssl
  rserver rserver-ssl
    inservice
Yuji
