ace module in bridged mode with client nat
f.makarenko
Could someone confirm whatever a NAT is supported for ACE-20 module, please?
Let me to explain technical details.
I do need to convert working CSM(SLB) config to ACE configuration and I am not quite sure
if the configuration below is correct. ACE module should be configured in bridge mode with two
vlans - vlan 36 (client) and vlan 436 (server) - bridged with interface bvi 36.
NAT on ACE configurad as "nat dynamic 1025 vlan 436" into corresponding
"policy-map type loadbalance"
Could you check two parts of configs and advise me if the ACE config is
properly converted from CSM and will be working in the same way (especialy for NAT).
Thank you in advance.
CSM config
vlan 36 client
  ip address 10.36.3.3 255.255.255.0 alt 10.36.3.4 255.255.255.0
  gateway 10.36.3.1
vlan 436 server
natpool WEB-MAIL 10.36.3.100 10.36.3.100 netmask 255.255.255.0
sticky 30 netmask 255.255.255.255 address source timeout 60
probe SHAREPOINT tcp
  interval 30
  failed 120
  open 3
  port 80
probe WEBMAIL-443 tcp
  interval 5
  failed 60
  open 2
  port 443
serverfarm WEBMAIL-443
  nat server
  nat client WEB-MAIL
  predictor leastconns
  real 10.36.3.101 443
   inservice
  real 10.36.3.102 443
   inservice
  probe WEBMAIL-443
serverfarm WEBMAIL-80
  nat server
  nat client WEB-MAIL
  real 10.36.3.101 80
   inservice
  real 10.36.3.102 80
   inservice
  probe SHAREPOINT
vserver WEBMAIL-443
  virtual 10.36.3.100 tcp https
  sticky 60 group 30
  replicate csrp sticky
  replicate csrp connection
  persistent rebalance
  inservice
vserver WEBMAIL-80
  virtual 10.36.3.100 tcp www
  inservice
ACE config
probe tcp WEBMAIL-443
  interval 5
  open 2
  passdetect interval 60
  port 443
probe tcp SHAREPOINT
  interval 30
  open 3
  passdetect interval 120
  port 80
serverfarm host WEBMAIL-443
  probe WEBMAIL-443
  rserver 10-36-3-101 443
    inservice
  rserver 10-36-3-102 443
    inservice
serverfarm host WEBMAIL-80
  probe SHAREPOINT
  rserver 10-36-3-101 80
    inservice
  rserver 10-36-3-102 80
    inservice
class-map match-all WEBMAIL-80
  match virtual-address 10.36.3.100 tcp eq www
class-map match-all WEBMAIL-443
  match virtual-address 10.36.3.100 tcp eq https
sticky ip-netmask 255.255.255.255 address source 30
  replicate sticky
  timeout 60
policy-map type loadbalance first-match WEBMAIL-80
  class class-default
    nat dynamic 1025 vlan 436 serverfarm primary
policy-map type loadbalance first-match WEBMAIL-443
  class class-default
    sticky-serverfarm 30
parameter-map type http HTTP_ADV_OPT
  persistence-rebalance
policy-map multi-match IFVLAN36-POLICY
class WEBMAIL-80
    appl-parameter http advanced-options HTTP_ADV_OPT
    loadbalance policy WEBMAIL-80
    loadbalance vip inservice
    loadbalance vip icmp-reply active
  class WEBMAIL-443
    loadbalance policy WEBMAIL-443
interface vlan 36
  bridge-group 36
  service-policy input IFVLAN36-POLICY
  mac-sticky enable
  no shutdown
interface vlan 436
  bridge-group 36
  nat-pool 1025 10.36.3.100 10.36.3.100 netmask 255.255.255.0
  no shutdown
interface bvi 36
  peer ip address 10.36.3.4 255.255.255.0
  no shutdown
chrhiggi
Level 3
Level 3
Hello F.Makarenko-
  You will want to use PAT while you do nat, so change the natpool configuration to this:
   nat-pool 1025 10.36.3.100 10.36.3.100 netmask 255.255.255.0 pat
  You also need to apply the nat like this:
class WEBMAIL-80
  class WEBMAIL-443
If you are going to build out a lot of classes, you can instead do source nat like this:
class WEBMAIL-80
class WEBMAIL-443
class class-default
Chris Higgins
chrhiggi
Level 3
Level 3
Hello F.Makarenko-
class WEBMAIL-80
  class WEBMAIL-443
class WEBMAIL-80
class WEBMAIL-443
class class-default
Chris Higgins
Hello Chris,
Thank you for your suggestion regarding source nat, I will try to implement it.
