ACE module statistics collection through SNMP
javiercastro
Hello Everybody,
What should I do in order to collect ACE module statistics through SNMP?
statistics = connections to each server load-balanced, etc...
sachinga.hcl
Level 4
Level 4
Hi javier,
As it is big topic so kindly go through the link mentioned below:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/admin/guide/snmp.html
I did not get your exact question so if further required plz help me in knowing what exactly you want to configure so that I can help you.
Plz revert.
Knd regard
sachinga.hcl
I was wondering if it is possible to monitor SLB statistics with a NMS using snmp. I hope there is a SLB MIB in order to gather this information and use it to manage the network.
Many thanks for your support.
Hi Javier,
Kindly tell if this information is of any use to you as we are also doing lot of migration these days from our many css to many ace blades as our network is much vast and diversified so all the config we are translating manually.
If any furhter help in this regard , please revert without hesitation.
Kind Regards,
Sachin Garg
