Bookmark
Subscribe
3424
ACE - Not able to configure Context
p.buitelaar
All,
I have configured an ACE with some contexts. I think I have configured it according to the documentation.
If I switch to a different context using the changeto command, I switch to the context, but get the following error message:
NOTE: Configuration mode has been disabled on all sessions.
Anyone has an idea how to solve this?
Thanks, Pieter-Jon Buitelaar
Gilles Dufour
Pieter,
you can only change the config on the active ACE. So, verify if you are on the active unit with the 'sho ft group det' command.
Gilles.
Gilles,
I am running a single ACE in single mode not in FT mode.
However, after rebooting the ACE module, I was able to go into conf mode in all contexts.
Any explanation for this behavior?
Thanks for your reply, Pieter-Jon
