ACE probe for Citrix
dpastor
I am running ACE 4710 appliance A3(2.5) and load balancing two servers running IIS 7.0 and Citrix v5.4.  I am using an HTTP probe to a specific login URL on port 81 and an expect status of 200-302.  The probes are up, and the site works, but the servers continually log errors indicating the source of the login is unknown.  Do I need to add a login script, or is there another parameter that I can add to the probe.
UPDATE: I added header User-Agent header-value "Cisco-ACE" to the probe, but we are still getting errors on the server "No user agent HTTP header".
Dave
amacuz
Hi Dave,
better would be to have a look at the traces and see if indeed the ACE does not send what is configured.
What do you see in there?
Alessandro
