ACE rate limiting per source
zhenningx
Level 4
Level 4
Hi, is there a way to configure ACE to perform rate liimting per source address? Say if a source sends more than 100 connections per second, I want ACE to drop further connections from this perticular source only.
thanks.
Nicolas Fournier
Unfortunately this is not possible on the ACE module at the moment.
You might be able to achieve something similar though by using the UBRL feature on the catalyst itself:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
Nicolas
