ACE reloaded automatically
samarjitdas
ACE which I manage at project site got reloaded automatically some days back with following details,
last boot reason:  Service "avs"
configuration register:  0x1
WEB-ACE kernel uptime is 4 days 9 hours 51 minute(s) 22 second(s)
Can you please help me out to know the root cause of such reboot.I went through lots of online search but nothing could help me out.
sivaksiv
Hi Samarjit,
What version are you running?
you may have to check this bug:
CSCte58902—Under normal operation, the ACE appliance reboots unexpectedly and generates an
AVS core file.
Siva
Hi Siva
Thanks for your quick response. IOS version ACE is running Version A3 (2.4)
Samarjit Das
hi Samarjit,
If the symptoms are matching upgrade to A3(2.6) to pickup the fix or you can raise a TAC case to confirm and get the crash files analyzed if any
Siva
