ACE resource oversubscription management
loudo
The ACE permits to allocate finely ACE resource for each context.
We can check the context resource usage by the command "sh resource usage".
The Denied outputs gives details regarding the "Number of denied resources because of oversubscription or resource depletion."
The question is how the oversubscription of resources between contexts is managed by the ACE? Can some prioritization between contexts be configured or this is just like fifo?
Many thanks for your help.
Regards/Ludovic.
mbittman
Thank you. We will look at the virtualization feature to see if it answer our needs.
Hi, The question is how the resources between contexts (when virtualization is used) are managed when resources oversubscription occurs?
Is is like fifo (first context served) or can we prioritize some (critical) contexts versus others?
Thanks. Regards/Ludovic.
