ACE Running S-NAT with IIs 6 logging
d.calton
Have a customer that is running IIS 6, and needs to source nat traffic from ACE module to those servers.  From what I can see, IIS 6 does not support/use “x-forwarded-for” header natively, and require an add-on module.  I found only one option (
http://www.winfrasoft.com/X-Forwarded-For.htm#Pricing).  Does anyone know of another option/approach to accomplish the same thing?  PBR not a viable option, BTW.
Surya ARBY
Level 4
Level 4
You can use any name you want in the field you add within http headers in the client's requests, but you'll always have to add a specific field.
