ACE sudden reload
eng__mohamed
ACE module reload sudden , i need to know what is the cause of this
kindly provide me how can i know the cause
sivaksiv
We would require following information to determine the root cause. You can attach it through a TAC raise or send them over to me.
1- 'show tech' on the switch
2- 'show tech' on the Admin context on the ACE
3- Logs on the switch covering the period when the reload happened.
4- Crash files from ACE located under "dire core:"
Siva
