ACE URL rewrite issue
juanrin75
I need to change the URL in the request from https://www.example.com to https://www.example.com/es/example/
I have tried several ways,both using location and Host, putting the dot and the slash between brackets [.] [/] with (.*) and %1, but none of them works.
If I check with show stats http, the counter of static parse errors increments and I have only achieved counts in the headers rewritten counter when changing the requests from http://www.example.com to http://www.example.com/es/example/
Is there any issue for this feature to add slashes / to the link in the SSL service?
Gilles Dufour
do you do ssl termination ?
If not, you can't modify the ssl content.
If yes, the procedure should be the same as for HTTP and you just add the ssl-proxy.
Gilles.
Gilles Dufour
Gilles.
No, the request is forwarded to an access gateway...
Thanks for the reply!
Wouldn't something like this work:
header rewrite request host header-value www[.]example[.]com replace www[.]example[.]com[/]es[/]example
Edit: I made the assumption that you do terminate the SSL tunnel on the ACE and that you have a SSL proxy configured to rewrite from http to https.
