ACE Virtual context -TACACS authentication issue
parveesm123
Hello All,
I have configured four context in ACE module.
I am trying to authenticate individual context through ACS.
Admin context authentication is working perfectly fine , and it is assigning the role of Admin for all the ACS users.
But when i am trying to authenticate other context , authentication part is working fine. but the user is not able to do any action other than show commands.
when i checked the user-account ( show user-account), it is given the role of Network-Admin .
Admin Context Output:
user:parvees.m
        roles: Admin
        domain: default-domain
        Context: Admin
Context ABC output
user:parvees.m
        roles: Network-Admin
        Context: ABC
Any help is highly appreciated.
regards,
Parvees M
ohynderi
Hello Parvees,
What value did you set to shell attrribute on your ACS? It should be like:
shell:ABC=Admin
If you take a capture (wireshark with your tacas secret), do you see this attribute-value being sent?
Olivier
Hi Oliver,
ACS shell following command has been added and it worked for me
shell:ABC ="Admin default-domain"
this has been repeated for all the domains... and it worked fine
regards,
Parvees
jackwikinski
Hi Parvees,
I also encounterd this when when configuring multiple contexts via ACS.
The solution is to use an asterik in the syntax after the context.
Without it you will receive network admin permissions as you have described below.
For example:
shell:Admin*Admin default-domain
shell:Web*Admin default-domain
shell:Parties*Admin default-domain
Hope this solves your problem.
Jack.
