ACE10 Strange behaviour
Akhtar Samo
Level 4
Level 4
Its strange to see the big difference in the system uptime and the kernel uptime. The ACE had caused a production impact for around 8 minutes and the standby ace didn't took over during that time frame although the FT/query vlan is configured perfectly fine.
Since there was no log generated on the 6500 switch for the module reset, i suspect that the module would have got hung and recovered by itself.
I also dont find any thing strange in the ft history * outputs.
I suspect that this might be a bug since the image is very old (Version A2(1.0))
`show system uptime`
System start time:          Tue Jun 12 10:41:12 2012
System uptime:              0 days, 20 hours, 5 minutes, 6 seconds
Kernel uptime:              5 days, 1 hours, 6 minutes, 8 seconds
last boot reason:  Unknown
configuration register:  0x1
ACE-1 kernel uptime is 5 days 1 hours 6 minute(s) 8 second(s)
`show ft peer detail`
Peer Id                      : 1
State                        : FSM_PEER_STATE_COMPATIBLE
Maintenance mode             : MAINT_MODE_OFF
FT Vlan                      : 503
FT Vlan IF State             : UP
My IP Addr                   : 2.2.2.1
Peer IP Addr                 : 2.2.2.2
Query Vlan                   : 502
Query Vlan IF State          : UP
Peer Query IP Addr           : 5.5.5.2
Heartbeat Interval           : 200
Heartbeat Count              : 20
Tx Packets                   : 14870
Tx Bytes                     : 3459966
Rx Packets                   : 14674
Rx Bytes                     : 3443749
Rx Error Bytes               : 0
Tx Keepalive Packets         : 14520
Rx Keepalive Packets         : 14520
TL_CLOSE count               : 0
FT_VLAN_DOWN count           : 0
PEER_DOWN count              : 0
SRG Compatibility            : COMPATIBLE
License Compatibility        : COMPATIBLE
FT Groups                    : 9
`show ft group detail`
FT Group                     : 1
No. of Contexts              : 1
Context Name                 : Admin
Context Id                   : 0
Configured Status            : in-service
My State                     : FSM_FT_STATE_ACTIVE
My Config Priority           : 250
My Net Priority              : 250
My Preempt                   : Enabled
Peer State                   : FSM_FT_STATE_STANDBY_HOT
Peer Config Priority         : 100
Peer Net Priority            : 100
Peer Preempt                 : Enabled
Peer Id                      : 1
Last State Change time       : Tue Jun 12 10:43:20 2012
Running cfg sync enabled     : Enabled
Running cfg sync status      : Running configuration sync has completed
Startup cfg sync enabled     : Enabled
Startup cfg sync status      : Startup configuration sync has completed
Bulk sync done for ARP: 0
Bulk sync done for LB: 0
Bulk sync done for ICM: 0
FT Group                     : 2
No. of Contexts              : 1
Context Name                 : Microsoft
Context Id                   : 2
Peer Id                      : 1
Switch logs:
%SVCLC-5-SVCLCNTP: Could not update clock on the module 11, rc is -1
Akhtar
Jorge Bejarano
Level 10
Level 10
Hello Akhtar,
As you said, probably the device might have started hunging at that moment then that´s why the failover was never fired, it would have been good to force a manual reset of the module.
There are some bugs which show: "last reboot reason: unknown" and they are called: "silent bugs" however the ACE might have had a process which was stuck at that moment. Do you have a high logging level?
Also you can check with: # dir core: to see if the device generated any core dump, here you have the link about it:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_Overview_of_ACE_Troubleshooting#Copying_Core_Dumps
Anyway, if the device did not generate any core dump, it will be good if you proceed with a proactive upgrade to the version:a2.3.3 or higher and monitor the behavior, in case you experience the same behavior, please try to collect #show tech-support if it is possible, if not hopefully the ACE will failover to its peer but it does not happen, force the reboot and trigger the failover and avoid further outage, but please be aware that as much information we got it will be better to determine the root cause.
Here you have the link where you can get the software from:
http://www.cisco.com/cisco/software/release.html?mdfid=280557289&softwareid=280836740&release=A2%283.6a%29&flowid=3314
Here you have a link about the upgrade process:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/administration/guide/upgrade.html#wp1008104
Jorge
