ACE30: Connectivity between IP subnets on the same VLAN being NATed?
sgonsalv
Hi Guys,
We have a subnet setup on the ACE as follows:
interface vlan 300
  description CALLISTA Environment
  ipv6 enable
  ip address 2001:388:608c:8b8::fffd/64
  alias 2001:388:608c:8b8::fffe/64
  peer ip address 2001:388:608c:8b8::fffc/64
  ipv6 nd ra interval 30
  ipv6 nd prefix 2001:388:608c:8b8::/64
  ip address 130.194.13.61 255.255.255.192
  ip dhcp relay server 130.194.15.17
  alias 130.194.13.62 255.255.255.192
  peer ip address 130.194.13.60 255.255.255.192
  ip address 130.194.19.220 255.255.255.224 secondary
  alias 130.194.19.222 255.255.255.224 secondary
  peer ip address 130.194.19.221 255.255.255.224 secondary
  access-group input ALLOW
  access-group input ALLOWv6
  access-group output ALLOW
  access-group output ALLOWv6
  nat-pool 1 172.16.25.231 172.16.25.231 netmask 255.255.255.255 pat
Notes:
There is the primary subnet 130.194.13.0/26 and the secondary IP subnet 130.194.19.192/27
The nat-pool is configured to allow server initiated connections to their frontend VIP when necessary.
We are noticing that when a server on the 130.194.19.192/27 subnet needs to communicate with a server on 130.194.13.0/26, albeit on the same VLAN, the destination server sees connections with a source IP of 172.16.25.231, which is the NAT address.  Is this expected behavior, where connections between IP subnets, albeit on the same VLAN are NATed?
thanks
Sheldon
Kanwaljeet Singh
Hi Sheldon,
Normally you should not need NAT but if you have a service policy applied which matches the conditions you have defined in class maps, the NAT will be applied.
You have mentioned that NAT pool is configured for server initiated conns and that must be the reason why traffic is getting natted because it must be matching the statement.
Kanwal
