ACE30 fail on first rserver - i'm stumped
hhorton
The short of the long story is this.  I have four rservers.  I have found that if the first listed server in my serverfarm is off line, the entire farm quits working.  How did I come to this conclusion?  You see as part of "serverfarm host PORTAL-FARM" rservers "SISPOAS1 through 4".  I can shut down any server except SISPOAS1 and all is well.  The load balancer sees the probes have failed to that given server and continuses to load balance to the others.  However, If I shut down SISPOAS1, nothing works.  I confirmed this by eliminating SISPOAS1 from the configuration completely.  After doing so, I could reproduce the exact same problem using SISPOAS2 since it is now the first rserver in the list after I removed SISPOAS1.  I'm stumped!  Looking at the configuration below, what am I missing???
access-list TRAFFIC line 8 extended permit ip any any
access-list TRAFFIC line 16 extended permit icmp any any
probe tcp 389
  port 389
  interval 2
  passdetect interval 2
  passdetect count 1
  open 1
probe tcp 636
  port 636
  interval 2
  passdetect count 1
  open 1
probe tcp 7777
  port 7777
  interval 2
  passdetect count 1
  open 1
probe tcp 7778
  port 7778
  interval 2
  passdetect count 1
  open 1
probe tcp 7780
  port 7780
  interval 2
  passdetect count 1
  open 1
probe tcp 7782
  port 7782
  interval 2
  passdetect count 1
  open 1
probe tcp 9401
  port 9401
  interval 2
  passdetect count 1
  open 1
rserver host FORMS1
  ip address 165.199.5.151
  inservice
rserver host FORMS2
  ip address 165.199.5.152
  inservice
rserver host SISPOAS1
  ip address 165.199.5.81
  inservice
rserver host SISPOAS2
  ip address 165.199.5.82
  inservice
rserver host SISPOAS3
  ip address 165.199.5.83
  inservice
rserver host SISPOAS4
  ip address 165.199.5.84
  inservice
serverfarm host BIS-FARM-SSL
  predictor leastconns
  probe 7780
  rserver SISPOAS1 7780
    inservice
  rserver SISPOAS2 7780
    inservice
  rserver SISPOAS3 7780
    inservice
  rserver SISPOAS4 7780
    inservice
serverfarm host FORMS-FARM-SSL
  probe 7777
  rserver FORMS1 7777
    inservice
  rserver FORMS2 7777
    inservice
  probe 389
  probe 636
  probe 7777
  probe 7778
  probe 7780
  probe 7782
  probe 9401
  fail-on-all
  rserver SISPOAS1
    inservice
  rserver SISPOAS2
    inservice
  rserver SISPOAS3
    inservice
  rserver SISPOAS4
    inservice
serverfarm host PORTAL-FARM-SSL
  probe 7778
  rserver SISPOAS1 7778
    inservice
  rserver SISPOAS2 7778
    inservice
  rserver SISPOAS3 7778
    inservice
  rserver SISPOAS4 7778
    inservice
serverfarm host RPORTAL-FARM-SSL
  probe 7777
  rserver SISPOAS1 7777
    inservice
  rserver SISPOAS2 7777
    inservice
  rserver SISPOAS3 7777
    inservice
  rserver SISPOAS4 7777
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY-PORTAL-CLIENT
  serverfarm PORTAL-FARM
sticky ip-netmask 255.255.255.255 address source STICKY-PORTAL-CLIENT-SSL
  serverfarm PORTAL-FARM-SSL
sticky ip-netmask 255.255.255.255 address source STICKY-RPORTAL-CLIENT-SSL
  serverfarm RPORTAL-FARM-SSL
sticky ip-netmask 255.255.255.255 address source STICKY-BIS-CLIENT-SSL
  serverfarm BIS-FARM-SSL
sticky ip-netmask 255.255.255.255 address source STICKY-FORMS-CLIENT-SSL
  serverfarm FORMS-FARM-SSL
ssl-proxy service BIS-SSL-PROXY
  key bisrsakey20120522.pem
  cert bis20120522CA.pem
ssl-proxy service FORMS-SSL-PROXY
  key forms0rsakey20130103.pem
  cert forms020130103CA.pem
ssl-proxy service PORTAL-SSL-PROXY
  key portalrsakey20120522.pem
  cert portal20120522CA.pem
ssl-proxy service RPORTAL-SSL-PROXY
  key rportalrsakey20120522.pem
  cert rportal20120522CA.pem
class-map match-all BIS-CLASS-HTTPS
  2 match virtual-address 165.199.5.159 tcp eq https
class-map match-all FORMS-CLASS-HTTPS
  2 match virtual-address 165.199.5.164 tcp eq https
class-map match-any PORTAL-CLASS-HTTP
  2 match virtual-address 165.199.5.158 tcp any
  4 match virtual-address 165.199.5.80 tcp any
  6 match virtual-address 165.199.5.159 tcp any
  8 match virtual-address 165.199.5.79 tcp any
class-map match-all PORTAL-CLASS-HTTPS
  2 match virtual-address 165.199.5.158 tcp eq https
class-map match-all RPORTAL-CLASS-HTTPS
  2 match virtual-address 165.199.5.80 tcp eq https
policy-map type loadbalance first-match BIS-POLICY-HTTPS
  class class-default
    sticky-serverfarm STICKY-BIS-CLIENT-SSL
policy-map type loadbalance first-match FORMS-POLICY-HTTPS
  class class-default
    sticky-serverfarm STICKY-FORMS-CLIENT-SSL
policy-map type loadbalance first-match PORTAL-POLICY-HTTP
  class class-default
    sticky-serverfarm STICKY-PORTAL-CLIENT
policy-map type loadbalance first-match PORTAL-POLICY-HTTPS
  class class-default
    sticky-serverfarm STICKY-PORTAL-CLIENT-SSL
policy-map type loadbalance first-match RPORTAL-POLICY-HTTPS
  class class-default
    sticky-serverfarm STICKY-RPORTAL-CLIENT-SSL
policy-map multi-match PPE-MULTI-MATCH
  class BIS-CLASS-HTTPS
    loadbalance vip inservice
    loadbalance policy BIS-POLICY-HTTPS
    loadbalance vip icmp-reply
    ssl-proxy server BIS-SSL-PROXY
  class PORTAL-CLASS-HTTPS
    loadbalance policy PORTAL-POLICY-HTTPS
    ssl-proxy server PORTAL-SSL-PROXY
  class RPORTAL-CLASS-HTTPS
    loadbalance policy RPORTAL-POLICY-HTTPS
    ssl-proxy server RPORTAL-SSL-PROXY
  class FORMS-CLASS-HTTPS
    loadbalance policy FORMS-POLICY-HTTPS
    ssl-proxy server FORMS-SSL-PROXY
interface vlan 5
  description Client-Side
  bridge-group 1
  access-group input TRAFFIC
  service-policy input PPE-MULTI-MATCH
  no shutdown
interface vlan 105
  description Server-Side
  bridge-group 1
  no shutdown
interface bvi 1
  ip address 165.199.5.9 255.255.255.0
  description Client and Server Bridge Group 1
  no shutdown
ip route 0.0.0.0 0.0.0.0 165.199.5.1
Kanwaljeet Singh
Just had a quick look at the configuration and it looks fine. Also, everything is working as expected unless you take that one server out of service or shut it down.
When that server is shut down what is the status of other servers in the farm? What is the status of serverfarm itself?
If the rservers are up and serverfarm is operational then this is not the expected behavior. I would suggest opening a TAC case for further detailed investigation.
Kanwal
Kanwaljeet Singh
Kanwal
Thanks for the response,
When the first server goes down, the server farm and the other servers look to be operational.  Only the server that we shut down is seen to be off line in the server farms state.  Yet, the application quits working like the loadbalancer isn't passing the data.  I'll would agree it's not expected behavior.  Looks like a TAC case is due.
Found my answer.  It had nothing to do with the way the load balancer was configured.  The issue was a configuration problem on the servers.
This is bit strange. Please let us know what exactly was wrongly configured on the server. This will help us to identify similar future event.
regards,
Ajay Kumar
