ACE30 module with 4 devices in HA mode
I have two ace module in ha mode, each ace are inside of a catalyst 6509, the catalyst  are in vss mode.
Iam going to install another vss with two ace module, I would like to know if is possible to configure the four ace module in  ha mode?
Fidel Gonzalez
Kanwaljeet Singh
Hi Fidel,
There can be FT redundancy between only two ACE's at a time. You cannot have 1 Active and 3 standby. It is not supported. But you can have two ACE modules in a single chassis acting as active-standby or in different chassis.
Kanwal
Note: Please mark answers if they are helpful.
Kanwaljeet Singh
Hi Fidel,
Kanwal
Hi Kanwalsi,
Thanks you for the quick answer.
Fidel Gonzalez
Hi Fidel,
You might want to check out this new product called ITD.
Simple and faster solution:
ITD provides :
  1. ASIC based multi-terabit/s L3/L4 load-balancing at line-rate
  2. No service module or external L3/L4 load-balancer needed. Every N7k port can be used as load-balancer.
  3. Redirect line-rate traffic to any devices, for example web cache engines, Web Accelerator Engines (WAE), video-caches, etc.
  4. Capability to create clusters of devices, for example, Firewalls, Intrusion Prevention System (IPS), or Web Application Firewall (WAF), Hadoop cluster
  5. IP-stickiness
  6. Resilient (like resilient ECMP)
  7. VIP based L4 load-balancing
  8. NAT (available for EFT/PoC). Allows non-DSR deployments.
  9. Weighted load-balancing
  10. Load-balances to large number of devices/servers
  11. ACL along with redirection and load balancing simultaneously.
  12. Bi-directional flow-coherency. Traffic from A-->B and B-->A goes to same node.
  13. Order of magnitude OPEX savings : reduction in configuration, and ease of deployment
  14. Order of magnitude CAPEX savings : Wiring, Power, Rackspace and Cost savings
  15. The servers/appliances don’t have to be directly connected to N7k
  16. Monitoring the health of servers/appliances.
  17. N + M redundancy.
  18. Automatic failure handling of servers/appliances.
  19. VRF support, vPC support, VDC support
  20. Supported on both Nexus 7000 and Nexus 7700 series.
  21. Supports both IPv4 and IPv6
  22. N5k / N6k support : coming soon
Blog
At a glance
ITD config guide
Email Query or feedback:ask-itd@external.cisco.com
