ACE30 not syncing with primary
mol.mini
Community Member
                   We did a faulty ACE30 module swap in a HA pair. Both the ACEs have stopped syncing since then. Below is the error message I see:
FT Group ID: 1  My State:FSM_FT_STATE_ACTIVE    Peer State:FSM_FT_STATE_STANDBY_CONFIG
                Context Name: Admin     Context Id: 0
                Running Cfg Sync Status:Failed to convert/transform configuration to peer version
Both ACE modules are running 5.2 with the same license.
sh ft peer status from both active and standby show the same results.
Peer Id                      : 1
State                        : FSM_PEER_STATE_COMPATIBLE
Maintenance mode             : MAINT_MODE_OFF
SRG Compatibility            : COMPATIBLE
License Compatibility        : COMPATIBLE
FT Groups                    : 15
Am I missing something here?
5 Replies 5
ajayku2
Check if there were certificates on the box. Ideally if SSL certificates are not copied then it is not going to Sync the config. Compare the SSL files on both the box. Copy all the SSL cert to the new box. Then it should sync fine.
mmol
Community Member
My understanding is that if its a SSL issue, it will go in COLD state and also display the error message that there is a missing crypto file. In this case, I see a different error.
Not all versions of code may display the reason for the config sync failure. I would first verify that all certs and keys are the same on both modules. This is the most common reason for this issue. If they are the same the next step I would take is to compare the two running configs to see if there are any differences. You can use a tool such as winmerge to compare. If you find any differences manually configure them to be the same and try the sync again.
Jim
mol.mini
Community Member
The problem was with the primary ACE module. It was missing startup file that it sends to the peer while sync process. I reloaded it and toggled the sync. Secondary started syncing just fine.
Hey Mini,
It sounds good it works now.
For future reference you may see the #show crypto files to compare the SSL files which you got in the boxes.
Additionally, please be aware that sometimes if there´s any crash in one device and generates a core dump file, they might detect that as a difference.
Then in general you may follow these instructions:
1) Check with #show crypto files
2) Compare both configurations.
3) Check #show version to see if there was a crash which you did not notice.
Hope this helps!
Jorge
