ACE30: Setting timezone issue
sgonsalv
Level 3
Level 3
Hi Guys,
This would seem trivial however I can't seem to set the appropriate timezone as indicated below:
Trying to set the timezone on our ACE30 modules (running A5(1.2):
clay1-ace/Admin(config)# clock timezone AEST +10
% invalid parameter detected at '^' marker.
clay1-ace/Admin(config)# clock timezone AEST ?
  <-23-23>  Hours offset from UTC
I cannot use the "standard" word because the ACST time would leave us 30mins out.
On our 3750 switches the following command just works;
clock timezone AEST 10
According to the Cisco documentation:
clock timezone {zone_name{+ | -} hours
hours — Hours offset from UTC. The range is from -23 to +23.
However I can't seem to set the hours as "+10"?
Sheldon
Jorge Bejarano
Level 10
Level 10
Shel,
And did you try something like this:
host1/Admin(config)# clock summer-time
Pacific 1 Sun Apr 02:00 5 Sun Oct 02:00 60
Additionally, for Australia timezone we got, as per the documentation:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_0/configuration/administration/guide/basiccfg_module.html#wp1401732
Australia
1)CST
Central Standard Time, as UTC + 9.5 hours
2)EST
Eastern Standard/Summer Time, as UTC + 10 hours (+11 hours during summer time)
3)WST
Western Standard Time, as UTC + 8 hours
Jorge
