SSL Issues
I am trying to get SSL to work. I have the configuration in place but it always just tells me there is a cert error and redirects to http. My config is below.
Thanks for any help!
-Andy
crypto chaingroup poweradvocatechain
  cert pabundle.pem
access-list allow line 8 extended permit ip any any
probe icmp PROBE_SERVICE_ICMP
  interval 5
  passdetect interval 5
  receive 5
probe tcp TCP443_PROBE
  port 443
  interval 5
  receive 5
  connection term forced
  open 2
probe tcp TCP7001_PROBE
  port 7001
  interval 5
  receive 3
  open 2
probe tcp TCP80_PROBE
  interval 5
  receive 3
  open 2
rserver host 228-WLS11host1
  ip address 192.168.211.228
  inservice
rserver host 229-WLS11host2
  ip address 192.168.211.229
  inservice
serverfarm host WLS11-7001
  probe TCP7001_PROBE
  rserver 228-WLS11host1 7001
    inservice
  rserver 229-WLS11host2 7001
    inservice
sticky http-cookie ACE_COOKIE-7001 7001_STICKY
  cookie insert browser-expire
  replicate sticky
  serverfarm WLS11-7001
ssl-proxy service prodproxy
  key poweradvocate.pem
  cert poweradvocate.pem
class-map type http loadbalance match-any L5
  2 match http url /.*
class-map match-all WLS11-7001-CLASS
  2 match virtual-address 192.168.211.50 tcp eq www
class-map match-all WLS11-HTTPS-CLASS
  2 match virtual-address 192.168.211.50 tcp eq https
policy-map type loadbalance first-match WLS11-7001-Policy
  class L5
    sticky-serverfarm 7001_STICKY
policy-map multi-match WLS11-SLB
  class WLS11-7001-CLASS
    loadbalance vip inservice
    loadbalance policy WLS11-7001-Policy
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 1000
  class WLS11-HTTPS-CLASS
    ssl-proxy server prodproxy
interface vlan 1000
  ip address 192.168.211.226 255.255.255.0
  access-group input allow
  nat-pool 1 192.168.211.50 192.168.211.50 netmask 255.255.255.255 pat
  service-policy input WLS11-SLB
  no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.211.235
Andy,
Everything looks fine as you can see here:
client pkt count : 24        , client byte count: 2532
server pkt count : 12        , server byte count: 2386
VIP State: INSERVICE
VIP is in service and traffic is reaching the ACE and is being sent to the servers.
What cert error are you getting?
I think you may need to get the root, inter and server certificate separated and then upload it to the ACE.
Jorge
12 Replies 12
Jorge Bejarano
Level 10
Level 10
Andy,
Can you paste the error you are getting?
You can check what you got wrong by typing the site in here, it will check it and let you know what's wrong.
http://www.sslshopper.com/ssl-checker.html
Why do you have your key, inter and cert certificates called in the same way?
Can show upload the "#show crypto files" output?
Jorge
It simply redirects me to the http page instead of going to the SSL page. The show crypto files output is below.
PA-ACE-4700-SLB/Prod-Support# show crypto files
Filename                                 File  File    Expor      Key/
                                         Size  Type    table      Cert
cisco-sample-cert                        1082  PEM     Yes        CERT
cisco-sample-key                         887   PEM     Yes         KEY
pabundle.pem                             3311  PEM     Yes        CERT
poweradvocate.pem                        3730  PEM     Yes        BOTH
Let me know your thoughts.
Thanks!
Andy,
I thought you said: "there is a cert error ", can you paste a screenshot of that error?
But how are you testing this?
Like this?
Https://192.168.211.50
Or
Http://192.168.211.50 and then it should be redirected to: Https://192.168.211.50?
How do you have this: WLS11-7001-Policy configured?
Can you do the following?
# clear stats all
Generate traffic and get the following:
# show service-policy WLS11-SLB class-map WLS11-HTTPS-CLASS detail
Jorge
I am testing it by going to https://192.168.211.50
the WLS-7001-Policy is defined here
  class L5
Eventually i want the redirect to work but now I am trying to get SSL to work. I am going one step at a time.
here is the output from the command:
PA-ACE-4700-SLB/Prod-Support# show service-policy WLS11-SLB class-map WLS11-HTTPS-CLASS detail
Status     : ACTIVE
Description: -----------------------------------------
Interface: vlan 1 1000
  service-policy: WLS11-SLB
    class: WLS11-HTTPS-CLASS
      ssl-proxy server: prodproxy
      nat:
        curr conns       : 1         , hit count        : 3
        dropped conns    : 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
     VIP Address:    Protocol:  Port:
     192.168.211.50  tcp        eq    443
      loadbalance:
        L7 loadbalance policy: WLS11-7001-Policy
        Regex dnld status    : SUCCESSFUL
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        Persistence Rebalance: ENABLED
        curr conns       : 1         , hit count        : 5
        dropped conns    : 0
        client pkt count : 44        , client byte count: 4334
        L7 Loadbalance policy : WLS11-7001-Policy
          class/match : L5
            LB action: :
               sticky group: 7001_STICKY
                  primary serverfarm: WLS11-7001
                    state:UP
                  backup serverfarm : -
            hit count        : 26
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
Thanks Jorge!
Andy,
Jorge
Hi Jorge,
I am going to upload the certs again. The weird thing is i just get a cert error from IE sayin the cert can't be verified. I click continue and then it just takes me to the http page. Its almost as if its redirecting me there. There is no cert error after i click continue however the url is just http://ace.poweradvocate.com (http://192.168.211.50)
I would think i would just be dumped into https://ace.poweradvocate.com with the cert error showing up saying it couldnt be verified.
Any thoughts on this?
Thanks!
-Andy
Andy,
Did you try to check your website with:http://www.sslshopper.com/ssl-checker.html ?
I suspect it might be related to the chaingroup at some point.
You said you tried with IE, which version? IE is always problematic.
  1. Did you try with Chrome, Firefox, Safari?
  2. Did you try to clear your browser cookies?
  3. Did you try from local subnet or a remote location?
Jorge
Hi Jorge,
Havent tried the ssl check yet as its all internal. I can set up a nat rule and check it out if necessary. I have tried ie9 10 and firefox and cleared cache all to the same results. If the cert is installed wrong would it just forward over to http and ssl would be unavailable or would it just show a cert error and I would still be able to access https?
Thanks!
Andy,
I think it should not show the content.
  1. Have you tried to access it via http only to make sure the page works just fine?
  2. Do your servers do any additional redirect or something?
  3. If you install the certificates in the servers directly and remove the SSL termination configuration from just to load balancing of 443 and let the servers to do the SSL termination, are you getting the same results?
  4. If you can modify and check it out with the link which I gave that will be great.
  5. Can you upload #show probeTCP7001_PROBE detail and #show serverfarm detail?
Jorge
Andy,
So what did you find?
Jorge
Hi Jorge,
I corrected all my certs and then realized the problem. The managed servers would redirect to /login automatically. I put in an https redirect and now the whole site is in https (which is good.) however there is one single page I want to be in http (its an auto redirect to the marketing site.) I am assuming i will have to create a seperate class map and policy map for this?
Thanks for your help.
-Andy
Andy,
Yes, it sounds you might need to match the other URI for that site and then do the redirect.
It is great everything is working now.
Jorge
