Additional Ways to Load Balance????
tadamson
We are currently using the following configuration for a number of situations on our 11501 (No SSL module).
content webapps443
protocol tcp
port 443
balance leastconn
vip address 192.168.2.106
add service webapps1
add service webapps2
add service webapps3
redundant-index 136
advanced-balance sticky-srcip-dstport
active
Is there any additional options that we could use to further load balance the traffic? We are having multiple clients where their source address is NATed, so those multiple clients are ending up on the same server when other servers are less active.
If I can't find any additional config options, we may have to look to getting a new box.
Gilles Dufour
this is not a problem a missing feature.
This is a general issue.
With SSL traffic, if you do not have an SSL module, the only information available to the CSS [or any other loadbalancer from any vendor] is the information contained in the IP,TCP and SSL headers.
There is nothing useful in the TCP header.
The only option in the IP header is the source IP.
And for the SSL header, you could use the SSLID.
However, this last option is very reliable as Internet Explorer is well-known for changing this ID very frequently during the same session.
Therefore, the only possible choice is source ip unless you can get an SSL module, then you can decrypt the traffic and use cookies.
Gilles.
