After WAAS deployment network is dead slow
asfar.zaidi
Hi All
After deploying WAAS , i.e. WAE-302 module in Cisco 2811 Router on core and edge with default setting and running wccp on the router , network is dead slow .
Core and edge network are connected with dedicated 2MB lease line.
License is Transport.
I can see traffic optimizing on WAE core and Edge but netwrok is dead slow.
Any suggestions.
mrjohnso
Level 4
Level 4
What was changed on the routers during this implementation? Only configuring the module, enabling wccp 61/62 and enabling redirection on the LAN/WAN interfaces?
Were additional routes added? Is it possible a routing loop was introduced? Do you see a reasonable number of connections on the WAEs?
I suggest looking at the following to see if any problems are indicated:
On the routers:
show ip wccp - should see most packets redirected via CEF
On the WAEs:
show wccp gre - look for any high counters that don't look right
type-tail syslog.txt 50 - look for messages indicating possible problems
todd.martin
If the network is slow I am assuming routing is OK. What applications specifically are slow?
if you disable WCCP in the WAE, is it still slow?
are the slow applications being optimized.
capture a trace of a transaction between the client and server on the WAE.
tethereal -s 1600 -w edge.dat -R "ip.addr eq x.x.x.x"
