ANM 4.1 virtual servers issues
DOUG KIRK
Frequent Visitor
Frequent Visitor
I just loaded ANM 4.1 and imported my ACE modules and I am seeing some odd behavior in the Operations/Virtual servers tab. My virtual servers are showing up with multiple different VIP addresses under the IP Address:Protocol:Port.
For Example VIP-WEB-80 shows up with the VIPs 192.168.1.1:80 and 192.168.2.35:443.  Only one of these addresses is associated with the VIP.  The other is associated with another VIP in a different context and different Policy Map.  Has anybody else seen this?  Is this a bug?  What can I do to fix this.
chrhiggi
Level 8
Level 8
Hello Doug-
Looks like - CSCtk63104.
Try checking the vips under the advanced configuration section, do they show up correctly?
Chris Higgins
chrhiggi
Level 8
Level 8
Hello Doug-
Chris Higgins
This is the Bug that TAC has identified.  It is scheduled to be fixed in 4.2 lated for release in Feb 2011.
