Application respose very slow while accessing through Cisco ACE 4710
hussainirfan
I have configure Cisco Load Balancer 4710. While i am accessing my applicaiton though load balancer virtual IP then its accessing very slow.
is there any configuration for fast response when using trough Load Balancer
thanks
Cesar Roque
Level 4
Level 4
Do you have a L7 lb or L4?
Please copy your class-map, policy and the relevant configuration to have a better picutre
--------------------- Cesar R ANS Team
Hi ceroque
thanks for you reply. please find the configuration for LB
thanks
Try creating a parameter type connection like this one:
parameter-map type connection test
  set tcp ack-delay 0
Then apply the parameter in the policy multi-match:
policy-map multi-match APP-POLICY-MAP
  class SSL-APP
    loadbalance vip inservice
    loadbalance policy APP-LB-POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 171
    ssl-proxy server SSL
    connection advanced-options test
_________________________________________
Cesar
I have done this configuration bus still i m facing same problem. Pelase see the capture file as well. it might have
some info for you.
thanks
